crank, start then die
We just finished putting a 402 in a 2002 z28.
its an ls2 bottom end with ls3 top end.
edelbrock 90mm tb with stock sensors
Ls3 injectors using caspers ev1 to ev6 adapters
the car will start and then immediately die. One time we had it running for about 20 seconds but that was it. Everything else is start and die.
it starts easy and giving it throttle doesnt help, it actually seems to make it not fire.
we had the battery off for 2 months until today. Not sure where to look.
Take off the cap that covers the shrader valve on the right side of the rail and push a small flathead into it and see if fuel comes out
yes, getting fuel at the rail. As an additional test, I used HP Tuners to disable the fuel pump and it wont fire at all, as soon as I turn the pump back on it fires, runs for a second and shuts off
