Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Speedometer Way Off
Old 01-16-2014, 11:10 AM
marcus88's Avatar
Default Speedometer Way Off
I bought a 98 z28 but noticed the speedo is way off.. At 60mph (speedo) actually 45mph @ 1500 rpm... Does this seem to be a gear a change? I want to get the pcm tuned but not sure of what is needed.. Any help would be appreciated..
Old 01-16-2014, 12:33 PM
97camaroguy's Avatar
rim size/tire size and a gear change could lead to the speedo being off. Try contacting the previous owner and ask them what gear they had installed.
Old 01-16-2014, 09:10 PM
maxharvard's Avatar
Gears could be the problem as could tires.
You could also have a bad VSS.
Old 01-16-2014, 09:20 PM
Atrus_SS's Avatar
You can figure out the gearing. Jack the vehicle up, turn the wheel 1 revolution, and see how many revolutions the driveshaft spins. If it's different than what the car rolled of the factory with, that could be it.
As someone mentioned, improper tire size can also throw off a speedo.
Old 01-28-2014, 07:39 PM
marcus88's Avatar
Thanks for the responses, the car has the original wheels as well as the correct tire size (245/50/16)...
Old 01-28-2014, 07:44 PM
marcus88's Avatar
Would the vss throw a code? If so I do not have a sel light..
Old 01-28-2014, 08:11 PM
maxharvard's Avatar
Not typically, but it's cheap so I say try that first.
Old 01-30-2014, 02:31 AM
1BurnedZ28's Avatar
Don't throw a VSS at the car without measuring your gear ratio which is in all likeliness what is causing your inaccurate cluster reading. VSS failures will typically (and i Do mean 99 percent of the time) cause the speedo to either be inoperable altogether OR incredibly erratic (Bouncing to 140mph to 0 to 75 etc). You WOULD also get a VSS code.
I'm constantly amazed by the "Throw parts at it" mentality so commonly found online. In no way shape or form would throwing a VSS at the car make the list of the first 5 things any GM tech would even do to diagnose this problem.
Quick Reply: Speedometer Way Off
