install new LED headlights
I have some projectors and the mounting brackets they come in are junk. I took the lights out and put them in the stock brackets it makes adjusting them so much easier it will save you a headache in the future.
Halogens and LED Running lights
I just installed a set of halogen and LED DRLs from protuninglabs. There was one bolt holding the headlight assembly in. Easy removal. The news ones installed quickly. The LED DRLs have to be hard wired into the regular daytime running lights. Red wire to blue, black wire to black. Simple. My LEDs are on when it is light outside and the headlights are not on. They also blink with the turn signals (if it is light outside) If it is nightime, they do not come on. You can correct this by wiring them to the side marker lights instead, but then they will only come on when you turn the parking lights on, or when the headlights come on automatically. Just a heads up on that. I chose to wire them to the regular DRLs, I am running clear DRL lenses for the stock DRLs.
Here are some before and after shots.
