Head light Problems
Head light Problems
My first post on here I have a 2002 Camaro with aftermarket lights. they had a led strip and some of the lights went out I took them apart and soldered some wires back together. the key feedback works and all the lights come on but when I put the switch to daytime no lights come on at all and only the headlights come on in the other position. Is there a fuse that im not seeing or could it be the control **** itself?
What do you have the wires for the LED lights rigged up too?
When i got my car one of the crappy halos wasn't working so they unplugged the other side. I traced the harness and the side that wasn't working wasn't working because they were wired into the marker lights and the positive wire came disconnected.
I would trace your wiring and make sure everything is connected well and not corroded in anyway or anything.
