99 z28 monster clutch release issues...Need Help
First the throwout bearing broke, I replaced the slave and throwout bearing. Clutch wouldn't fully disengage. Went ahead and changed the master cylinder, was able to drive it to the store and back then the same thing happened(won't release) . It's acting like the slave needs to be shimmed, but the original one didn't need it. There's no visible damage to the pressure plate, clutch, or pilot bearing. What would cause it to not fully release the clutch. There is absolutely no air in the line(manual bled and used Mityvac), and I've measured the slave to the pressure plate( is at 1/16 difference after I did the formula)
I could really use some advice this is my dd.
