Needed helpppp
Motor and Tranny just bought the car it had a blown head gasket and I have a built motor for it and I don't no much about these cars everything is disconnected but steering column and brake lines
Are you sure you have all the bolts out? Did you unbolt the bellhousing from the block or the bellhousing from the rest of the transmission? There should be slots where you can get a pry bar in between the block and bellhousing which would help you get it out. Just approach the job with a little patience, force and the right amount of leverage and it should be no issue. Having a friend help can go a long way. Work safe.
