Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
My 2000 Camaro z28
Old 05-19-2015, 09:47 AM
tonightkiller14's Avatar
Default My 2000 Camaro z28
Ihttps://i.imgur.com/5aeAfYm.jpg
I have a camaro z28 dark blue with these mods:
*ls6 intake.
*1/3/6 headers.
*MF exhuast system with cat back.
*shift kit trans go.
*SLP air filter.
*racing oil pump.
*racing breck pads.
*aluminum saft.
the car is dyno tuned and have a 334 Hp.
what do you think of the power and what I should do next to make the car live longer .
p.s. I have a seccond car. So this is my ride for having fun.
Old 05-19-2015, 01:14 PM
Nathan C's Avatar
334 is a great number for a 2000 ls1 car. Early stock LS1's dyno about 280-295. What do you mean by making the car live longer?
Old 05-19-2015, 05:02 PM
Default thanx bro
I meant what kind of mods i need to do to make the engine and the transmision run smothly without any problems.
any advice what to do next ?
And I have a question whats the best ratio for the car 3.73 or 4.10?
Thanx and i know its a good number coz the car has only 74,000 km .
Old 05-19-2015, 07:52 PM
LE35TH's Avatar
Great numbers!
I would probably go with the 3:73s, if its a car you're going to cruise your rpms may be high when on interstate etc.
Old 05-20-2015, 08:45 AM
Default thanx
What do you think of the bodykit should I remove it ?
coz I want to install a racing suspension Eibac kit and if with the bodykit I wont be able.
And what about the rims 18 do you thing if I go with lower size it would be a good thing?
Old 05-20-2015, 09:24 AM
LE35TH's Avatar
I personally don't care for the body kits, but you have to be careful with how it was installed. I know that the RS body kits actually drill into the body so if you remove it you would have holes in the body.
The wheels don't look bad, but its a bad angle to really see them. Are they a 2 or 3 piece design? Just look like it because of the rivets/bolts, but they could be fake. I personally like stock 17s or if I was to go with aftermarket wheels it would be a 17/15 drag pack or a nice set of forged wheels like the Fiske or CCW that some people on here run.
Its your car though, all that matters is that you like getting into the car every time you drive it and it makes you grin.
Old 05-20-2015, 10:21 AM
DANOZ28's Avatar
mag article ls1 do's & don'ts says 3:73's , i would probably go stall & 3:42's. also add welded sfc's & lca's for better traction. just my one cent. after that 228 cam & ls6 heads. ls2 timing chain is a good upgrade for $50.
Old 05-20-2015, 04:31 PM
I want to make the car a special car
the cam for the long run is it going to harm the engine ?
the sfc and lca what will give the car ?
Old 05-22-2015, 12:26 AM
myk
myk's Avatar
Leave the body kit and the wheels on-it looks great as it is...
Old 05-23-2015, 02:23 PM
2JAWZ's Avatar
yes,, ditch the body kit!
Old 05-23-2015, 02:45 PM
Mappinsj's Avatar
my 2000 camaro has 3.42 with automatic, doesnt give you the same hole shot as 3.73, but i would absolutely never go with 3.73 unless i tracked my car alot. (you will never win a roll race with 3.73 in your auto )
Old 05-24-2015, 12:34 AM
Default hi
So the best is to go with 3:42?
And whats the best stall to go with?
Thanx everyone
Old 06-05-2015, 07:41 AM
Default Cam
I want to know is cam going to harm the engine in the long run .?
Whats the best cam for my car I dont want a big cam i want somthing in the middle if its not going to harm the engine.
Old 06-23-2015, 01:34 AM
Default What to do next?
I have installed sfc and rear sway bar to my car .
now what do you advice me to do next ?
Old 06-23-2015, 06:07 AM
HCI2000SS's Avatar
Maybe something along the lines of a 228r cam and a stall
Old 06-26-2015, 08:08 PM
Mappinsj's Avatar
i am also 100% on the 3.42, my car has them and i am automatic, i would not for anything go 3.73 unless i was going to the track ALOT
i have won many roll races with my 3.42
Old 08-27-2015, 08:25 AM
Default Installed a new 3.42 ratio
I have installed a new 3.42 ratio after using the car when I reach 60 km/h
I hear a noise from the back I think its the new ratio sound .
Is that ok or there is somthing wrong?
Quick Reply: My 2000 Camaro z28
