Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
HELP! 02 SS Trans Mount Issue
Old 06-25-2015, 01:49 PM
02SSFregolle's Avatar
Default HELP! 02 SS Trans Mount Issue
Hey guys hopefully someone can help...recently installed a energy suspension polyurethan trans mount on my 02 SS m6. After installing the mount the transmission started leaking around around the tail shaft. My mgw shifter is also slightly cocked to the right. Shifts and drives fine but need to figure out what went wrong. Called energy suspension they have no clue, just offered me a smaller mount .Car also has spohn solid engine mounts. Thanks!
Old 06-25-2015, 01:57 PM
redbird555's Avatar
Is it where the tails haft mates to the main case or the seal where the driveshaft yoke is? There's mount is usually taller than stock so that may be an issue. Personally with solid or poly engine mount a poly trans mount isn't much better than a good rubber oem one
Old 06-26-2015, 12:35 PM
Honestly you cant tell since there is oil all over the driveshaft/tail shaft area. I'm thinking when the mount was installed the Tranny was shifted somehow, that explains why my shifter now sits at a slight angle
Quick Reply: HELP! 02 SS Trans Mount Issue
