Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
1999 Camaro Turn Signal switch
Old 07-30-2015, 02:37 PM
Maguilacutty's Avatar
Default 1999 Camaro Turn Signal switch
Hello everyone , I am not sure whats going on with my turn signals. When I purchased the car I realized that only the right turn signal worked when I click it down to turn left nothing happened ,the blinking light on the instrument cluster would stay solid green instead of blinking and the signal outside of the car wouldn't work either. Now right nor left signals are working , they stay lit up instead of blinking. Keep in mind that i'm talking about inside the car the lights are solid on the instrument cluster instead of blinking. The turn signals are also not working outside. Could it be the actual switch? Please help
Old 07-30-2015, 02:43 PM
JimMueller's Avatar
Check the bulbs in the turn signal housings, the bulbs are likely burned out and need to be replaced.
Old 07-30-2015, 05:38 PM
2002maroonZ28's Avatar
Your flasher needs to be replaced
You can pick one up at any auto parts store for under $10.
The flasher is located under the the steering column to the right. Take out the cover, pull the old one out and plug in the new one!
Quick Reply: 1999 Camaro Turn Signal switch
