2001 Camaro Brake Light Woes!!!
Ok so it started when I noticed that my turn signal would stop working when I applied the brakes, I then found that my driver side brake light wasn't working and assumed bad bulb.
Now 6 hours later and I have replaced every bulb on the back end plus the 2 front turn signals and cleaned each terminal and I am back where I started!
I'm loosing my mind, every other light works the signals work fine at idle but a few seconds after applying the brakes it stops clicking.
Here is a quick video, it doesn't show the driver signal as I forgot to show it but it does work.
http://youtu.be/UsdXuwmA4m8
Any help and or recommendations
