99-02 PCM and Harness Questions
I know the 98 F-bodies have a different PCM and engine harness that isnt at all compatible with the 99-02 stuff.
I have a 99 V6 car that I am V8 swapping, and I am curious if the three large connectors that interface the PCM harness to the front-clip body harness are the same between the V6 and V8 cars? That same question applies to the two small connectors that go through the passenger side of the firewall to under the dash.
Second question is, what part # is the LS1 PCM from the 99-02 cars? I need the IAC driver on the PCM and I figure getting a PCM from the same car will assure the wiring harness matches up and the factory electronics will work correctly.
Also if anybody has a 99-02 LS1 PCM for sale PM me, I have a thread in the parts section also. Thanks guys!
Sorry I wasn't very clear in my original post, I wanted to know if the connectors that the engine harness connects to the body harness with are the same between the V8 and V6 cars because I want to get a V8 harness and PCM
I did some digging and it would appear the connectors should be plug n play to mate the body and engine harness. Alot seems to depend on the year of the swaps however so stay away from 98's.
http://tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
