Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Odd clunk when starting from a stop or slowing
Old 10-01-2015, 11:12 AM
CorbinD's Avatar
Default Odd clunk when starting from a stop or slowing
I have a 1997 camaro automatic z28 and it has a weird thud or clunk sound when I slow down or start from a stop. Also if I start accelerating and then take my foot of the gas as its about to shift it really thunds. I know it can't be the transmission mount because I replaced it with a polyurethane one. However when I bought the car the transmission mount was broken so it was driven for a while with a broken mount. Could that have caused damage. The transmission usually has a firm hard 1 to 2 shift but other than that I think it's good.
Could the clunk be the transmission downshifting? Or could it be a bad bushing or something. When it happens from a start it feels like to car is really slow then a second later it thus and takes off
Thanks, sorry for the long post
Old 10-01-2015, 06:13 PM
DuckDude's Avatar
Check caliper bolts, axle bolts, all suspension bolts, torque arm bolts (that brace that runs next to the axle) Maybe there is a loose bolt and things are shifting around...
Old 10-02-2015, 06:43 AM
CorbinD's Avatar
Alright, will do when I get time
Thanks
Could a bad torque arm bushing cause this because mine looks like it is ripped up
Old 10-06-2015, 02:29 PM
DuckDude's Avatar
Find anything? I just realized I said to look at the torque arm running parallel to the axle.... I meant drive shaft.. Sorry. But anyway..
Old 10-06-2015, 02:30 PM
DuckDude's Avatar
I wouldn't dismiss that theory... see if you can move it around by hand maybe...
Old 10-06-2015, 03:15 PM
CorbinD's Avatar
Thanks I tighted up some bolts but also replaced the Torque arm bushing I think it was a combination and the clunk went away. The torque arm bolts in the differential were loose as well as some other things.
Thanks for all the help, problem solved
Old 10-08-2015, 06:02 PM
DuckDude's Avatar
No prob!! That's awesome to hear!! I know you feel a ton better now that it's taken care of and the noises are gone.
Quick Reply: Odd clunk when starting from a stop or slowing
