Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
rims and tires
Old 07-31-2016, 06:14 PM
jakeswader's Avatar
Default rims and tires
what is the widest rim and tire I can put on my 1998 f-body Camaro without having to mini-tub it or tub it
Old 07-31-2016, 07:00 PM
HCI2000SS's Avatar
Usually a 315 tire with an 11 inch rim
Old 07-31-2016, 07:54 PM
jakeswader's Avatar
when you say usually what is some of the problems I could run into
Old 07-31-2016, 07:56 PM
jakeswader's Avatar
when you say usually what could I run into
Old 07-31-2016, 07:59 PM
HCI2000SS's Avatar
Rubbing on the inner wheel well and/or the lip of the outer wheel well. It's kind of hit or miss with these cars. Some of the easy and common solutions are to roll the lip of the outer wheel well, beat the inner wheel well with a hammer, an maybe use an adjustable panhard bar
Old 07-31-2016, 08:40 PM
jakeswader's Avatar
well I know I'm going to be running a 10 inch rim so if I ran the next size down from a 315 you think I would be alright I know it might be a hard thing to know until you try it
Old 07-31-2016, 08:43 PM
HCI2000SS's Avatar
Yeah it really is hard to say for sure, but yes in general a 10" rim with maybe a 295 or 305 should have no issue whatsoever. If you are lowered this becomes more of a problem as well
Quick Reply: rims and tires
