Power window problems
I have a 2002 Camaro Z 28 and yesterday both of my Power windows stopped working at the same time. Will not go down or up on either driver or passenger side. Checked the window fuse on the left side of the dashboard 30 amp and it was fine . Looking for advice thank you
before yesterday, were they both working fine? motors are known for failing on these cars, but if it doesnt move at all, it can also be a bad switch. Ive replaced a bunch of window motors, and only one time it turned out to be a bad switch.
so what it turned out to be on the passenger side window motor was a bad electrical connection and on the driver side the motor was bound up which caused the thermal switch to kick in allowed to do nothing. Removed both motors fix electrical connection on blinded the other all repaired. Just a freak occurrence of both going out at the same time
