Cam sensor code 2000 camaro V6
Hey, i know there have been alot of threads about this, but i have read through them all but none of them have helped. So far i have replaced the cam sensor, tested it and replaced the pigtail. Replaced the ignition coils(all of them) replaced the ignition control module, spark plug wires and spark plugs, and pcm. I checked through the whole wiring harness. I still have this code and it is the only code that comes up. If you can help that would be great.
Also if it helps the mods that i have done are obx headers, full 2.5 inch stainless steel exhaust, tuned pcm 90° header wires, and a 180° thermostat. Again thank you.
