02 Camaro Horn power issues
Hi so I was fixing my horn on my 2002 Chevy Camaro v6 and air bag and by accident I touched the positive wire with the ground wire I seen a little smoke *** the plastic around the wire got a little melty and hot now I don't have any power coming to my horn I check the fuse and it wasn't blown and ideas what it could be?
So after checking my horn the relay works I get power from under the hood relay to the steering wheel column but from the column to the steering wheel I have no power. I ran a direct positive wire from the relay outside of the car to the steering wheel and the horn works
Check to see if you have continuity between the horn relay and the steering column on the black wire. Also check to see if there is continuity to ground at both ends of the black wire. Need to know the wire was not damaged when you touched it with the ground.
Yes I didn't use power I used a continuity tester to test the wire from the relay to the steering wheel column the from the black wire on the steering wheel column to the steering wheel it was good up until I got to the steering wheel column to the steering wheel
