Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Old 05-13-2016, 04:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
LS1 SS vs LS1 Z28
Old 10-27-2004, 12:51 PM
IWannaSS's Avatar
Default LS1 SS vs LS1 Z28
what are the differences between an LS1 SS and LS1 Z28. other than body differences what are the other differences?
Old 10-27-2004, 05:38 PM
Gary3282's Avatar
different intake and exhaust(cat-back), suspension and rims
Old 10-28-2004, 08:38 AM
IWannaSS's Avatar
to what extent is the intake and exhaust different. is it just the lid and the catback or the both manifolds?
Old 10-28-2004, 02:03 PM
It's not mine! woo hoo!
demonspeed's Avatar
There is no difference in the lids unless it's an 02 with the optional 345hp package - which are few and far between.
The "ram air" goes in the scoop and swings around like a rams horn and into the bottom of the lid - just like the lid on the Z28. So it's only the hood that makes a difference - IMO, it doesn't make a difference.
The exhaust is hardly a step up as well. A little throatier, but other than that, it's not too useful when you compare ¼ performance. Again, you could go with the 335hp exhaust or the 345hp package with the lid and exhaust.
The only thing that would give the SS an advantage over the Z28 is the tires on the SS being wider (275 vs 245).
There is no suspension difference 00-02 unless it has the optional bilstein or 1LE package. 98/99's had bigger sway bars and different springs I think though... might not be true - someone correct me if I'm wrong.
The only reason I got my SS is because of the way it looks. It's not any better than my Z28 was.
Old 10-29-2004, 06:40 PM
ReaperSS's Avatar
there is no diffrence in the SS's unless its a SLP Model. yes all come from slp but the base SS doesnt have the SLP options except for hood and wing. Both are mine are SS but not SLP, so they are basically a Z28 with a hood and a wing. Lids, susp,etc. are all the same as a Z28
Old 10-29-2004, 10:18 PM
vetteemt's Avatar
I'm pretty sure that in 98 all the SS's came with the 1LE springs and Sway bars. Not 100% sure on that tho.
Old 10-30-2004, 01:42 AM
CaMaRoZ28LS12000's Avatar
That is one thing I hate. A lot of people talk about the SS like is a lot faster than a Z28 when in reality they are both the same power wise. I have seen stock SSs and Stock Z28s run the same times at the track. The appearance is the only real difference between the two.
Old 10-30-2004, 10:55 AM
ReaperSS's Avatar
LOL i agree with you. I cant stand the mustang guys bragging about racing a SS or complaining about racing one. Its not a big deal. even if its a SLP option car wow 5-7 hp diffrence As for times. every car runs differant times as everyone knows from a 13.7 Z28 to a 13.0 Z
Old 10-30-2004, 11:13 AM
BDiddy#11's Avatar
this is kinda off topic....but does the Z-28 have a composite or steel hood?
Old 10-30-2004, 11:29 AM
CarrotcarZ's Avatar
i believe it is a steel hood, because its a lot heavier than the SS hood!!
Old 11-05-2004, 12:11 PM
That's what she said...
TheBlurLS1's Avatar
definatly steel lol
Old 11-09-2004, 08:01 AM
JackZ28's Avatar
Z28 racing heritage > SS racing heritage!
Old 11-26-2004, 11:54 AM
35thZ28Man's_wife's Avatar
[QUOTE=DMNSPD]There is no difference in the lids unless it's an 02 with the optional 345hp package - which are few and far between.
Do you know the code for this option?
TIA
Old 11-26-2004, 02:59 PM
demonspeed's Avatar
[QUOTE=Angel_Eyes]
TIA
There is no code. It's just listed on the SLP sticker as "345hp package" or something to that effect.
Old 11-26-2004, 11:16 PM
Oh ok, I thought that there would be a code on the info, just got an 02 SS Vert, bought it from auction, just thought I would check all the specs, thanks!
Old 11-27-2004, 10:30 AM
demonspeed's Avatar
The only code for anything about the SS that is listed in the RPO would be WU8 for the SS package and Y2Y if there are any SLP options.
Old 11-27-2004, 06:58 PM
NKAWTG...N
StoleIt's Avatar
zl1 racing heritage > z28/ss
and what spoiler is that on ur z28?
Old 11-27-2004, 10:03 PM
Got the Y2Y code, thank you so much and I knew about the WU8 code for the gears.
Thank you for all your help!
Robin
Old 11-28-2004, 09:14 AM
demonspeed's Avatar
Robin
WU8 is the SS RPO. The gears are GU5. Just give slp a call or email them with your VIN number and they'll tell you what Y2Y options your car has.
Old 11-28-2004, 01:42 PM
Sorry about the ati knew te code for the gears, I was answering a PM when I wrote that...
WU8-SS Performance/Appaerance
GU5-323 Gears
Y2Y-SLP Options
Just tying to get my ducks in a row before anymore mods are done to it.
Quick Reply: LS1 SS vs LS1 Z28
