Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Anybody know the Vin. ID for Iroc
Old 04-15-2005, 08:21 PM
Nine Finger 02 Z28's Avatar
Default Anybody know the Vin. ID for Iroc
I recently bought a car and was looking to verify info on the car.A break down of the Vin # would be nice if anybody knows.Thanks
Old 04-15-2005, 08:37 PM
ACW
ACW's Avatar
The IROC-Z was technically just an option package, so it will not be indicated in the VIN.
Old 04-15-2005, 08:42 PM
So then is there a way to verify an Iroc from a Z28?Or anything to look for besides Badges or engine size this 1 orginally came with a 5.0 acording to the sticker under the hood.
Old 04-15-2005, 08:44 PM
ACW
ACW's Avatar
What year is the car?
Old 04-15-2005, 08:46 PM
It is an 86
Old 04-15-2005, 08:51 PM
ACW
ACW's Avatar
Originally Posted by Nine Finger 02 Z28
It is an 86
Aha, found an IROC-Z Spotter's Guide!
http://www.iroczone.com/techartspottersguide.html
- The RPO code was B4Z
- Base Engine:
LG4 "Quadrajet" Carbureted 305 CID (5.0L) V-8
- Optional Engine(s):
L69 "Quadrajet" Carbureted H.O. 305 CID (5.0L) V-8
LB9 Tuned Port Injection (TPI) 305 CID (5.0L) V-8
- Colors available were White, Black, Bright Red, Yellow Gold, Bright Blue and Dark Red Metallic
- A 'unique' feature of the 1986 IROC-Z, is that the third brake light was located on top of the hatch window, close to the roof. Later year, base model Camaros had the brake light in the same location as most did not have a rear spoiler.
Old 04-15-2005, 09:00 PM
Thanks.Yeah mine has the 3rd Brake light 85mph speedo and the Registraion is due Jan which would hint to an early 86.Is there a way to check the Vin to see how it came as far as options and equipped?
Old 04-15-2005, 09:13 PM
ACW
ACW's Avatar
Unfortunately, no... here's a recent thread about where to look for the car's RPO list sticker: https://ls1tech.com/forums/racer-s-lounge/305327-can-gm-anyone-tell-me-rpo-list-87-z28-just-vin.html
Old 04-16-2005, 01:33 PM
It's not mine! woo hoo!
demonspeed's Avatar
The only way you can use the VIN to tell if it's an IROC is the 88-90 cars since there was no Z28. 85-87 cars were just RPO's. So if you don't have the RPO code (should be in the glovebox), you can take your VIN to the dealership and they should be able to get you a list of RPO codes.
Old 05-11-2005, 02:26 PM
mxz700adrenaline's Avatar
go to thirdgen.org they got a butt load of info on third gen the rpo skicker should be in ur center box will tell u everything and thirdgen.org has rpo decoder thing but look for b4z is the iroc pkg. and 88-90 irocs will say z28 because there was no z28 in those years just iroc u should have z28 and b4z and i dont know this for sure but i know 87 and up all irocs had the 145 speedo dont know for sure about 85 and 86 i think its the same way and irocs came with leather wraped shifter and e brake if this helps u out
