Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Old 05-13-2016, 03:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
Common 4th Gen problems??!!
Old 12-26-2005, 11:11 PM
Nakoz's Avatar
Default Common 4th Gen problems??!!
Well I was working on my car today.... again... and was just thinking of how many things I have actually replaced that have either died or failed since I have gotten my car. I noticed that alot of other people where having the same common OEM issues that I had. Here is the list of things that I had to replace on my car alone, not moding, just replaced. Please post up if you can think of any more:
1. 10 bolt
2. Battery
3. Passenger Signal bulb
4. 3-4 shift fork
5. Reverse Syncro
6. Passenger window motor
7. Clutch
8. Rear hatch lock
9. Front and Rear Rotors
10. Rear Shocks
11. Possibly new water pump
Old 12-26-2005, 11:17 PM
Deranged Rat Fink
badjuju342's Avatar
So far , I've replaced the tires and a turn signal flasher on the T/A , nothing major at all.
zombie1's Avatar
Damn! The only thing I have replaced was a battery.Dealer replaced a pinion seal,alternator, pcm.Under warranty.
Old 12-26-2005, 11:25 PM
Nakoz's Avatar
Damn.... I feel shafted now...
Old 12-27-2005, 08:22 AM
Michael02hawk's Avatar
1. 10 bolt
2. Battery
4. 3-4 shift fork
5. Reverse Syncro
7. Clutch
8. Rear hatch lock
10. Rear Shocks
12. Piston Slap
Old 12-27-2005, 10:12 AM
bbfirebird's Avatar
I've replaced (in order):
1. Oil pan gasket (started leaking when I started running synthetic after I bought the car with 25k miles on it)
2. Battery
3. Driver and passenger side headlight motors
4. A/C compressor
5. A/C idler pulley and tensioner (went out after a new belt was put on after condenser was replaced and underdrive pulley was installed)
In the future, I imagine I will have to replace both power window motors, as those frequently wear out, as well as the power antenna. All are working fine now, but we'll see what happens.
Old 12-27-2005, 10:50 AM
Fenster's Avatar
Only thing I have replaced on the SS is the front turn signals. They are a common item that have to be replaced on all the 4th gens. Get water in the housing and fry out. Not too bad considering it could be worse.
Old 12-28-2005, 10:05 AM
DubyaSsixTA's Avatar
1. turn signal socket and bulb
2. alternator
I've been pretty lucky so far (knock on wood). Mine doesn't even squeak enough for me to notice, lol
Old 12-28-2005, 10:28 AM
jmurray87's Avatar
Right turn signal flasher
rear main seal
oil pan gasket
drivers side window motor
tranny mount
thats about it for me.
Old 12-28-2005, 10:49 AM
It's not mine! woo hoo!
demonspeed's Avatar
I think the most common problems are:
Front turn signal socket and bulb
Belt tensioner
Brake Rotors
Window Motors
Speakers
Clutch
Rear (with abuse)
Old 12-28-2005, 06:23 PM
METALBEAST's Avatar
How many miles does your Camaro have on it?
Old 12-28-2005, 06:45 PM
BOBA_VETT's Avatar
I replaced practically everything on my LT1, until I got fed up and replaced IT with an LS1.
On my LS1, I've done:
1. Brake rotors (they warp easy)
2. Alternator
3. Battery (since the stupid alternator was gone, it drained the battery)
4. Turn signal-o-rama (does it ever end!?!)
5. Water pump (No Optispark to go to hell with the water pump, woohoo!)
That's 'bout it, with close to 76k on the dial. Considering my 3rd gen and LT1 had 10x that, I'm pretty pleased... and waiting for the pain.
Old 12-28-2005, 07:16 PM
RobDarden's Avatar
I've replaced due to failure:
1. Driver window motor
2. Driver window trim
3. Black plastic triangular trim piece on convertible
2001 SS with 35,000 miles on it.
Old 12-29-2005, 07:43 PM
Nakoz's Avatar
Ooo yea, i forgot one more thing... I had the roof replaced... Under warrenty.... Paint started to bubble and peel next to the windshield. Also had the spoiler replaced for the same issue.
Damn, seems like the turn signals are in the lead for OEM replacement....
Old 12-30-2005, 02:31 AM
Chaotic Firebird's Avatar
The previous owner replaced/fixed everything listed.
Opti-spark for the LT1 owners.
Water pump.
Drivers side window motor.
Drivers side headlight motor.
What if fixed/replaced.
Rear squeak caused by worn endlink bushings.
Crappy DeCarbon shocks with Bilsteins.
Old 12-30-2005, 02:55 AM
99HUGGRSS's Avatar
2000 z-28
ring and pinion, 2:73(blown bearing)easy driving
o2 sensors
both cats
tranny(lost 3rd gear) clutch packs
engine??? think i have bad rings, but still runs good
front and rear rotors
31000 miles
1999 ss
abs module
gauge cluster(showed error - bad odometer)
battery
almost driver side t-top(doing 70 on i-40, flew off and landed in the mud in the median) not a scratch. THANK GOD
9200 miles
Old 12-30-2005, 11:19 AM
Kenafin_02TA's Avatar
WS6:
-transmission (twice)
-both front turn signal socketts (and multiple bulbs)
-10-bolt
-rotors
-battery
-low-beam headlights
-added second spring to trunk release
-seatbelt holder on driver's seat
not too bad I guess for 75K miles....
Firehawk:
-driver's window motor
-rotors
-2 10-bolts
-battery
-seatbelt holder on passenger side
-clutch
-front turn signal bulb on passenger side
-added spring to trunk release
not going to complain with this list either and 70K miles...
Old 12-30-2005, 02:22 PM
Trev_SS's Avatar
i have only replaced
-clutch
-a/c fan
-tires
Old 01-02-2006, 02:02 PM
CJDZ24_Z28's Avatar
01 SS nothing
48,000 miles
94 Z28
window motor,Optispark dist.,bad 02 sensor and cat but all this @ 115,000 miles
Old 01-05-2006, 06:38 AM
Bill Bowling's Avatar
Talking
2001 SS with 27K. No problems but a CAT under warranty at 12K. Dealer messed up the threads. Last time at a dealer.
Bill
Quick Reply: Common 4th Gen problems??!!
