Need help with fittings
I am installing a 2000 Camero LS1 with a 4L60E trans in a 1962 Corvette.
I am trying to solve the problem about the fuel line fittings and would appreciate any help you guys can give me.
I have installed the "Tanks" fuel pump in my tank and it has pipe threads that I can connect my hard lines to........no problem with that. My problem is what fitting can I get for my supply and return line that will go from a 3/8 inverted flare hard line to the factory style lines that are connected to the fuel rails. I will run the 3/8 hard lines for both the supply and return line.
If anyone has the part number, the part discription, ot the part size and where I can buy them you would have helped me out a lot.
Also if it would be better to run flexible lines please give me that information .
Thanks,
Wade
Thanks,
Wade
