need some help with an iroc
I'm gettin ready to buy a 1986 Camaro Iroc Z
My questions are...
Is it a 350 or 305?
What rearend/ gear ratio is it?
if its a 350...
what carb should i get in the meantime before the lsx swap
thanks in advance
My questions are...
Is it a 350 or 305?
if its a 350...
thanks in advance
if its an 86 its a 305. Gm did not offer the 350 to the public till 87
carbed? lg4... i had one and it was a total slug... lol
whats the engine code on the vin number?
I realy liked my 86 Iroc. Yet it did have a cammed TPI 305. I never had it timed but it felt like it would give my 98 z28 some good competition.
I would do a simple swap to a carburated crate 355 or 383 or something.
A LS swap woul not be direct fit and would require some fabrication work.
fabin isnt a prob, i want somethin that gets decent fuel mileage that is also fuel injected. my truck gets 12mpg on a good day lol
im thinkin an ls1 or ls2
If you have the money go with a LS7. You'll do some serious spankin with that. Honestly an LS1 or LS2 would probably be the best choice to keep the budget realistic.
Its true that you can make lots of power for alot less money with a carb, but I like fuel injection better simply because you can drive them everyday with good power and decent fuel mileage. Alot of people are scared of fuel injection because of the computer and all the wiring, but if you pull one apart you will see that the wiring really isn't that hard to figure out. Plus you can have the computer tuned to make more power without taking the engine apart. Just my opinion, I like them both but if I have to drive the car alot I like fuel injection better.
In-Zane Moderator
In this world EFI and carb are close really. A carb wil seliver tons of power with a little less mileage than EFI, but it simply depends on how much you stab the throttle. If you have money and time with skill then EFI can be your thing with unlimited tuning curves.
EFI doesn't even take skill, its been engineered to the point of just being plug and play. But carbs are much cheaper and all you have to do is set it ontop of an engine, fire it up, and adjust it until it runs smooth. EFI is good because you can plug it, get the timing close, and let the computer do the rest. If you take the time to lay everything for an EFI system out you can easily figure out where every sensor and plug goes. They really are not hard, I think alot of people have either heard bad things or they look at all the wiring and just assume that it is too complicated.
Not true. You can buy everything to make it a bolt in swap. I fabbed absolutley nothing for my swap that I did nearly 4 years ago. I can just imagine how much more is being made for these swaps nowadays.
