Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Turn signal flasher relay..2002 camaro where is it?
Old 08-02-2008, 07:12 AM
99VetteMan's Avatar
Default Turn signal flasher relay..2002 camaro where is it?
My turn signals stopped flashing last night as I can no longer hear the relay making noise when I try to signal. Where the heck is it exactly on a 2002 camaro?
Regards,
Jason
Old 08-02-2008, 10:39 AM
Hennytime's Avatar
ditto, my 00 has the same issue
Old 08-02-2008, 09:00 PM
EnfuegoZ28's Avatar
Under the steering column. Pull the panels off that are under the steering column and you will see a fuse panel. The turn signal flasher is round and silver. Easy to get to and easy to change, but enjoy crawling under the dash. lol!
Old 03-30-2020, 03:58 PM
frerkingdylan's Avatar
Idk if you'll see this but do you just pull it off? Working on mine now and it seems extremely hard to get off. Like theres a clip of some sort holding the silver to the red plug...
Old 04-01-2020, 09:01 AM
JohnnyBs98WS6Rag's Avatar
Check for burned out turn-signal bulbs, they can cause the flasher to slow or stop. I've never had a flasher fail, but lots of bulbs burn out.
Old 04-02-2020, 12:57 PM
v6buick's Avatar
Beat me to it. This is usually the case. I've managed to limp mine along by bending the contacts inside and greasing the heck out of them, but the plastic is all melted. It's been working like that for about two years.
Quick Reply: Turn signal flasher relay..2002 camaro where is it?
