High beam problem need help - LS1TECH
Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Thread Tools Search this Thread
Old 09-03-2008, 10:57 PM   #1
bongva's Avatar
Default High beam problem need help
Ok so my highbeams dont work, When i pull it back it doesnt make a noise or anything like a relay... it just pulls back and nothing happens, does anybody know what is going on?
99 z28 m6 if that has anything to do with it.
bongva is offline   Reply With Quote
Old 09-04-2008, 10:14 AM   #2
bongva's Avatar
bump please need help... need highbeams
Old 09-04-2008, 10:34 AM   #3
Untouchable436LS1's Avatar
well if you've done anything around the steering column i would check for a loose connector, if you are lying in your floor board and you look at the steering column there are 3 bolts that attach the column itself, there are connectors lying around there, and one of them goes to your highbeams, just something to rule out i guess
Untouchable436LS1 is offline   Reply With Quote
Old 09-04-2008, 12:33 PM   #4
checkbit's Avatar
there should be a switch (i think it's called a dimmer switch or something like that) in the underside of the steering column that gets actuated by a rod when you pull the multifunction lever to turn on the high beams. i replaced one years ago. i can't tell you exactly where it is or what it looks like, as i don't remember. i can tell you it's cheap to replace, though.
easiest thing would be to go to a small service garage that does NOT charge to look at problems and see what you need.
checkbit is offline   Reply With Quote
Old 09-04-2008, 01:38 PM   #5
Ntimid8r7's Avatar
^ yep, you need a new switch. mine is the same way right now. it pulls back but has no click.
Ntimid8r7 is offline   Reply With Quote
Old 09-05-2008, 12:27 AM   #6
bongva's Avatar
alright i will try that... thanks guys!
Related Topics
Thread Thread Starter Forum Replies Last Post
How to remove crank balancer 2fast4u1989 LT1-LT4 Modifications 4 04-10-2014 12:08 AM
bbc valve lash adjustment. johnson73801 Small Block & Big Block Chevy Specific 1 01-24-2009 09:14 PM
obdII guys-reluctor wheel lt1mc LT1-LT4 Modifications 5 08-29-2007 08:13 PM
Car dies for a sec at low rpms? Gun5 LT1-LT4 Modifications 3 08-27-2006 06:15 PM
Phamspeed turbo leak SELLSZ06 Forced Induction 28 09-10-2005 10:40 AM
Tags
beam, high, ls1, problem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
