2011 ERL LSX All Motor rules - LS1TECH
Chevrolet Performance LSX Challenge Series & Shootout Chevrolet Performance Nationals Atlanta Dragway Commerce, GA June 3-5, 2016 Chevrolet Performance LSX Shootout Lucas Oil Raceway Park Indianapolis, IN June 23-26, 2016 NMCA World Street Finals Summit Motorsports Park Norwalk, OH August 25-28, 2016 Holley LS Fest Beech Bend Raceway Bowling Green, KY September 9-11, 2016
Closed Thread
Thread Tools Search this Thread
Old 01-07-2011, 02:45 PM   #1
LS1Tech Sponsor
Default 2011 ERL LSX All Motor rules
GENERAL OVERVIEW
This is a NATURALLY ASPIRATED heads-up shoot-out style drag racing class.
Developed for naturally aspirated LS small block GM powered and bodied cars and trucks.
All races are on a .400 Pro Tree and in a heads up format.
This will be an ALL RUN qualifying format.
Vehicles are required to be stock appearing and stock bodied.
All vehicles MUST pass NHRA/IHRA safety inspection for ET and speed.
A Sportsman ladder will determine running order.
Vehicles must be driven to staging and to scales, can be towed after scales
Vehicles are required to run GM Performance Parts Sponsor decal and GM Performance Parts LSX Shootout license plate
WEIGHTS
Base CID Base weight
370 2600
420 2800
440 2850
470 2950
5.0 lbs/cu in penalty applies for cubic inches over base weight break limit. (Maximum cubic inch still applies.) All weights are with driver & rounded down to the five pound increment. Ex: A calculated weight of 3228 would be required to weigh 3225 with driver at scales.
WEIGHT ADDER/DEDUCTS
# OEM style intake manifolds deduct 100 lbs.
**Canted Valve cylinder heads add 100 lbs.
*Manual transmission – weight penalty of 125 lbs. added to base weights
Ladder bar suspended combinations add 50 lbs.
Non OEM 4-link suspended combinations add 100 pounds
Entries with two throttle bodies or two carburetors (including 2 split dominators) add 50 lbs
ENGINE
Only LS based small block engines are allowed.
Cast aluminum or iron block required
Displacement will be verified by using the P&G method
Maximum of (2) mufflers are mandatory
4-inch maximum exhaust exit size
Gasoline is the only fuel allowed
Cylinder heads limited to LS OEM or LS OEM “Style” aftermarket head.
Billet cylinder heads are prohibited
**Canted valve variations permitted with 100 lbs. weight adder
Cylinder head must be identifiable to verify legality
Any modifications allowed to legal heads
Sheet metal intakes permitted
Dry sump oiling systems permitted
CARBURETOR/INDUCTION
Any style carburetor permitted including split dominators-maximum 2-carbs add 50 lbs.
Any EFI system permitted. Maximum of 2 throttle bodies. 2 throttle bodies add 50 lbs.
Any Intake manifold allowed, including sheet metal/fabricated manifolds (*see weights)
Any modifications permitted, manifold must be identifiable
TRANSMISSION
Any OEM style automatic transmission permitted
Any non-planetary style manual transmission permitted *Manual transmission – weight penalty of 125 lbs. added to base weights.
Any torque converter allowed. Lock-up type permitted.
Torque converters not permitted with manual transmissions
Clutch-activated automatic transmissions (re: Clutch-flite) are prohibited
SUSPENSION
Aftermarket K-members allowed
Mini tubs and notched frame rails allowed
Factory rear frame rail required in OEM location
Wheelie bars are permitted
Stock type suspensions permitted with stock mounting locations
Non-OEM 4-links permitted with 100 lbs weight adder
Coilovers permitted
Front-wheel drive conversions prohibited
INTERIOR
Must be original appearing.
Floors must be upholstered, headliners required
Two seats are required in stock location, rear seat may be removed
OEM appearing dash required
BODY
Forward facing hood scoops prohibited except for OEM type
Cowl induction hoods permitted, 6” max
Light-weight or fiberglass body pieces limited to hood, doors, trunk/hatch and bumpers
Overhangs must be OEM, Wheelbase must be OEM +/- 1”
Replacement fiberglass/carbon panels must maintain OEM appearance and function
Rear spoilers permitted, max. length 26”, may not be molded into the body
WINDSHIELD/WINDOWS
OEM safety glass or Lexan Permitted. Window tint is prohibited forward of the “B” pillar. Tinted windows are not permitted forward of the “B” pillar, per NHRA requirements.
ELECTRICAL
Electronic driving aids prohibited
Throttle stops, delay boxes and auto shifters prohibited
Two-step, trans-brakes and line-locks are permitted
Functional headlights, taillights and horn required
Any aftermarket ignition permitted
TIRES-WHEELS
TIRES - FRONT: Front tires must have a minimum tread width of 4.5 inches.
TIRES - REAR: Street type or racing slicks permitted
Maximum actual measured tire size is as follows:
Actual measured tread of tire is limited to 10.75 inches by 30.5 inches tall
Actual tire width will be measured by a “go - no go” gauge after conclusion of run at scale area
Tire tread may not extend outside fender lip.
“W” tires prohibited, tire shaving prohibited
SPECIAL NOTES:
Absolutely no nitrous or other power-adder equipment will be allowed on the vehicle.
Nitrous plates, solenoids, soft or hard lines, nozzles, bottles or disconnected superchargers must be removed.
NMCA REQUIRED DECALS:
NMCA WINDSHIELD DECAL – must be installed on top of windshield. This NMCA decal must be the only decal on top of windshield. Other vehicle sponsor decals may be placed at base of windshield.
NMCA SIDE DECAL- must be installed on side widow of vehicle.
CLASS SPONSOR DEACAL- GM Performance Parts decal must be installed on lower right side of front windshield.
CONTINGENCY DECALS:
Decals are required to appear only on the rear quarter windows or rear window in a clear and orderly fashion. Contingency decals may not be overlapped or modified.
ALL MOTOR PURSES:
Florida, Georgia, and Kentucky Events:
$1,500 Win + Contingency + Plaque
$750 R/U + Plaque
$375 Semis
$100 Quarters
LSX Shootout – Indiana Event:
$2,000 Win + Contingency + GMPP LSX Bowtie Block + Jacket + Plaque
$1,000 R/U + Plaque
$500 Semis
$100 Quarters
Robin L is offline
Old 01-14-2011, 07:58 AM   #2
LS1Tech Sponsor
MADMAN's Avatar
Rules look great. Only one issue, the rear tire. Nobody makes a 30" tire or a 29.5 with 90" or less rollout. You still have to run a 28 to get there.
MADMAN is offline
Old 01-14-2011, 09:35 AM   #3
LS1Tech Sponsor
The roll out rule was accidently left in from last years rules it has been removed.
Robin L is offline
Old 01-14-2011, 06:48 PM   #4
LS1Tech Sponsor
MADMAN's Avatar
Thanks Robin.
MADMAN is offline
Old 08-01-2011, 05:07 PM   #5
REDGAR's Avatar
Please see midseason rule adjustments
http://ls1tech.com/forums/gm-perform...nt-2011-a.html
REDGAR is offline
Closed Thread
Related Topics
Thread Thread Starter Forum Replies Last Post
2011 JE Pistons LSX Drag Radial Rules Robin L Chevrolet Performance LSX Challenge Series & Shootout 0 01-07-2011 02:43 PM
2010 Final JE Pistons LSX Drag Radial Rules & Purse nmcajeff Chevrolet Performance LSX Challenge Series & Shootout 1 07-08-2010 10:36 PM
2010 Final ERL LSX All Motor Rules & Purse nmcajeff Chevrolet Performance LSX Challenge Series & Shootout 1 07-08-2010 10:33 PM
2010 Final LSX Real Street Rules & Purse nmcajeff Chevrolet Performance LSX Challenge Series & Shootout 1 07-08-2010 10:26 PM
Wheres the turbo limits in real street? tim99ws6 Chevrolet Performance LSX Challenge Series & Shootout 39 03-23-2010 05:53 AM
Tags
2011, block, challenge, commerce, corvette, cylinder, engine, erl, ga, head, lsx, motor, rules, shoot, shootout
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
