All motor rule changes?????? - LS1TECH
Chevrolet Performance LSX Challenge Series & Shootout Chevrolet Performance Nationals Atlanta Dragway Commerce, GA June 3-5, 2016 Chevrolet Performance LSX Shootout Lucas Oil Raceway Park Indianapolis, IN June 23-26, 2016 NMCA World Street Finals Summit Motorsports Park Norwalk, OH August 25-28, 2016 Holley LS Fest Beech Bend Raceway Bowling Green, KY September 9-11, 2016
Thread Tools Search this Thread
Old 03-23-2011, 10:17 PM   #1
WESTPORT AUTO's Avatar
Default All motor rule changes??????
just putting it out there,should there be some changes made so we can get a more competitive field and higher car count?????? weights? transmissions? tires?
WESTPORT AUTO is offline   Reply With Quote
Old 03-23-2011, 10:59 PM   #2
GrahamHill's Avatar
Nope. Apparently the competition needs a carrot... and they have one.
GrahamHill is offline   Reply With Quote
Old 03-24-2011, 08:34 AM   #3
DBN
DBN's Avatar
Quote:
Not a carrot. A sponsor with deep pockets.
DBN is offline   Reply With Quote
Old 03-24-2011, 12:54 PM   #4
vetteboy2k's Avatar
What kindof changes would people like to see and please think of the entire class not just one car.
1) Allow e85
2) No penalty for stock manual trans
3) Consideration for IRS suspension (weight break?)
4) 28" tire max( some cars can't even fit a 28")
5) Raise the overall weight limits back up a few hundred pounds
6) 200lb penalty for clutchless?
Just some thoughts.
vetteboy2k is offline   Reply With Quote
Old 03-24-2011, 02:29 PM   #5
GIZMO's Avatar
Quote:
Originally Posted by vetteboy2k View Post
1) Allow e85 - If anything there should be a spec fuel for this class. Alternative fuels (E85) don't fit this kind of racing.
2) No penalty for stock manual trans - I would be fine with this, but I think you will see a lot of broken transmissions.
3) Consideration for IRS suspension (weight break?) - This class is already to the point that an IRS is dangerous by NHRA standards.
4) 28" tire max( some cars can't even fit a 28") - The 30" tire is fine.
5) Raise the overall weight limits back up a few hundred pounds - I think that would be a dumb idea. I like the new base weight. I would like to see a true lbs/ci rule instead of the random stuff that they have now.
6) 200lb penalty for clutchless? - When the qualified field is closer and this shows itself as an issue it should be addressed.
I have added my thoughts to yours. I am guessing that you have a certain car that you were aiming your thoughts at?
GIZMO is offline   Reply With Quote
Old 03-24-2011, 03:12 PM   #6
Did yall actually this this would be a mid to high 8 sec class forever???????? One car has there combo figured out, the rest just need to catch up. spend the money to get the car lighter??????????? I dont have a problem with gizmos suggestions, added to the current rules.
spoooled is offline   Reply With Quote
Old 03-24-2011, 04:10 PM   #7
vetteboy2k's Avatar
Quote:
About the dumb idea. Some folks are saying it's hard to make weight and I agree. It could be dangerous to keep lightening to try and be competitive and that's one way to level the field but I'm cool with seeing how things play out. So, if the rules state that my car could be 2500lbs it doesn't help me because it physically can't. Plus why stock looking interior if everything else is suggesting racecar.
Old 03-24-2011, 04:11 PM   #8
vetteboy2k's Avatar
Quote:
Most classes seem to settle in somewhere due to the rules.
Old 03-24-2011, 04:36 PM   #9
GIZMO's Avatar
Maybe dumb was too strong of a word.
If I can actually get my junk to run over 6000 rpm I will be at Atlanta. I have plans to run the last two races too. I know that I will not be competetive, but If the series continues into 2012 I would be up to building a class specific car. At that point the weight would be a non-issue as I would build it as light as possible regardless of what combination I run.
Old 03-24-2011, 04:37 PM   #10
The SAM car will run low 20s with a little more work, surely faster in good air. its not hard to get these cars light it just takes effort, and they are safer at the lesser weight with the 25.5 or 25.2 or 25.3 cage.
Old 03-24-2011, 04:51 PM   #11
I have a what if for you...what if there was an n/a class for 9-second cars?
-T56, 4L60E, 4L80E, 6L80E, 200-4R, TH400, TH350, and Powerglide were the only transmissions allowed.
-Intake manifold was limited to either factory, FAST (or other stock style), or an Edelbrock Victor Jr (with a limited carb/throttle body size)
-Canted valve and C5R heads would be prohibited, with weight breaks for factory castings
-Factory PCM
-Stock suspension only, 28" tire, weight break for IRS
-weight system would be based on cubic inch, with the base being at 2900lbs for a 346cid motor
How many people would commit to a four race series based on those rules?
Scott@GMHTP is offline   Reply With Quote
Old 03-24-2011, 06:23 PM   #12
10 second playa
Anonymous's Avatar
-Factory PCM
I like these rules.
Any limits on the cam? Would Solid Rollers be allowed or Hyd only?
Anonymous is offline   Reply With Quote
Old 03-24-2011, 07:22 PM   #13
vetteboy2k's Avatar
Cool. I guess in a drag race anything can happen so you have a chance.
Old 03-24-2011, 07:45 PM   #14
REDGAR's Avatar
-Factory PCM
If we stayed toward the higher side of 9 I would be in.
REDGAR is offline   Reply With Quote
Old 03-24-2011, 09:07 PM   #15
-Factory PCM
If this is what you want just go run NHRA stock class. You will still spend lots of money to do that and have more rules than you can stand. Remember somebody will always go faster no matter what the rules.
Z06 CU is offline   Reply With Quote
Old 03-24-2011, 10:13 PM   #16
did yall actually this this would be a mid to high 8 sec class forever???????? One car has there combo figured out, the rest just need to catch up. Spend the money to get the car lighter??????????? I dont have a problem with gizmos suggestions, added to the current rules.
its not a weight issue for everyone else,its the liberty without enough weight penalty.then lets top it off with a bigger tire so its easier to set up the clutch.not everyone has unlimited funds.
Old 03-24-2011, 10:34 PM   #17
5.3LJimmy's Avatar
-Factory PCM
I AM IN!!!
I do my best to make every race I can to run index(Though the birth of my daughter and my brother's wedding are keeping me out of the last two this year). If there was a heads up class that fit the 9.5 to 10.5 N/A cars I'd definitely run that instead. I think the stock PCM is the perfect equalizer for a slower heads up class as it prevents folks from revving the crap outta their combo(safely anyway).
5.3LJimmy is offline   Reply With Quote
Old 03-25-2011, 10:42 AM   #18
GIZMO's Avatar
Quote:
Is it really that big of an issue at the moment? (Unless you want to add 500 lbs)
The tires are a plus for all combinations. Even six cylinder Stock Eliminator cars run a 30" tire.
Old 03-25-2011, 02:47 PM   #19
fasttagurl's Avatar
Quote:
I second this...
Most of us will never have $30k to build a motor like SAMs.
fasttagurl is offline   Reply With Quote
Old 03-25-2011, 04:40 PM   #20
SlickVert's Avatar
1) Allow e85
Just some thoughts.
I think that the weight penalty for canted valve heads is not relevant anymore with the new GM DRX heads and others that flows as good of better then some canted.
Maybe a 100lbs penalty for all square port heads and No penalty for cathedral heads might work better.
SlickVert is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
how to change password notfastenough User Support & Resources 3 04-30-2016 04:31 PM
change username GPMadness08 User Support & Resources 1 04-29-2015 01:54 AM
Changes for 2011 models 325trooper Gen 5 Camaro External Bolt-On Tech 63 09-18-2009 09:15 AM
still waiting dkbykesdk 10 Second Club 5 04-02-2008 10:47 PM
Pulley change (ATI) White SS Forced Induction 5 06-01-2003 08:12 AM
Tags
baskins, car, comp, eliminator, engine, gateway, international, ls1, ls1tech, lsx, motor, raceway, rule, sale, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
