What steam line comes out on the passenger side?
I have a 2004 LQ4 and the front steam line barb comes off on the driver's side. What steam line comes out on the passenger side?
Originally I was running stock injectors,LS1 intake and stock throttle body.After taking to the dyno/tuner I am changing to a ported throttle body,42gph injectors, and a LS6 intake.
Would like to "clean up" the back and forth steel and rubber lines under the throttle body.
Last thing you want is icing in the throttle body. I once had a car with a carb that had a heat riser tube off of the exhaust manifold. The heater tube fell off, and the carb completely iced up while driving in the Chicago area during winter. Keep the heat in the TB; you live where it gets really cold.
Yes! that is what I am looking for! Thanks Les SS. My coolant cross over tube or steam line is from a 04 LQ4.I had to ben it to clear the throttle body and with it barbed on the drivers side I have not only the steel tube under the TB I also have a rubber line going from the driver's side barb, to the top of the water pump on the passengenger side.Too much cluttler.Looks like LS2 crossover/steam line is what I need thanks guys! P.S. awsome notchback Les SS.
keep in mind ls2 CARS have the crossover line on the drivers side. you would have to use one from the tbss
