Compact LS Accessory Drive
Accessory Drive (with air) LS1,LS6 19155066
[No reason you couldn't use this on any LS with the Corvette balancer and Water Pump]
This kit was originally designed for CTS-V type engine bays and is taller and narrower than the 19155067 kit.
Measurements from the crank center line: vertically 17.0" high, drivers side is 12.0" wide, and passenger side is 12.5" wide.
•Deluxe Kit includes all the components and hardware necessary to install on an engine with air conditioning, including water pump, alternator, power steering pump and idler bracket. (Belt included).
The system includes:
12572188 Belt (water pump, alternator, and power steering)
12569528 Belt (A/C compressor)
12568181 Tensioner Assembly
12560345 A/C Belt Tensioner Assembly
12557334 A/C Compressor idler Pulley
1137031 A/C Compressor
12556444 A/C Compressor Bracket
15261472 Power Steering Pump (reman)
12555222 Power Steering Bracket
12578068 Alternator and Power Steering Pump Bracket
12555693 Power Steering Pump Brace
12559890 Power Steering Pump Pulley
10353440 Alternator
26046502 Power Steering Reservoir
10353440 Alternator
