WOOHOO it starts!, 5.3 in 99 wrangler
Old 11-07-2008, 12:21 PM
LUMPY85's Avatar
Default WOOHOO it starts!, 5.3 in 99 wrangler
it starts up, but it only runs for about a sec, about as long as it takes me to let off the crank position. then it dies. but its damn close to running, i had to clean my injectors out last night, 6 out of 8 were still stuck after soaking them in seafoam.
any suggestions on what to look for, it throws a couple egr codes but that is all,
Old 11-07-2008, 12:30 PM
95PGTTech's Avatar
did you disable the VATS? sounds like the security system is shutting it down. does it make good vacuum?
Old 11-07-2008, 01:02 PM
LUMPY85's Avatar
havent checked vacuum, vats was supposed to be disabled by lt1350.com, not sure if i trust it though
Old 11-07-2008, 10:31 PM
JIMB's Avatar
Default Dies after starting.
Make sure you have power (12 volt) to the computer on start and run key postion.
Need test light to confirm.
Old 11-07-2008, 10:40 PM
LUMPY85's Avatar
i checked, got 12volts in both positions,
Old 11-08-2008, 02:16 AM
95PGTTech's Avatar
good fuel pressure?
Old 11-08-2008, 03:23 AM
LUMPY85's Avatar
58 psi the whole time
Old 11-13-2008, 09:46 AM
Big Geek's Avatar
It is a classic symptom of the VATS. I would see if it is disabled.
Jim c.
Old 11-13-2008, 10:53 AM
LUMPY85's Avatar
i sent my computer off yesterday
Old 11-13-2008, 01:41 PM
lsxyj's Avatar
kool good luck give us more info on ur build
Old 11-13-2008, 05:11 PM
LUMPY85's Avatar
ill post some pics these are from a month ago, ill get better and more tomorrow. these were cel phone pics btw
Attached Thumbnails WOOHOO it starts!, 5.3 in 99 wrangler-7eff93c57bf5.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-8bd5bb7bfae2.jpg
Old 11-14-2008, 12:38 PM
LUMPY85's Avatar
pics of the jeep
Attached Thumbnails WOOHOO it starts!, 5.3 in 99 wrangler-dscn2515.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-dscn2521.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-dscn2524.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-dscn2525.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-dscn2527.jpg
WOOHOO it starts!, 5.3 in 99 wrangler-dscn2528.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-dscn2530.jpg   WOOHOO it starts!, 5.3 in 99 wrangler-dscn2531.jpg
Old 11-15-2008, 12:36 PM
aknovaman's Avatar
Guess you decided not to come over for a tune. When you get your mail order PCM back, drive it over and I'll show you what you got for your $.
Probably not much.
Old 11-15-2008, 12:52 PM
Red89GTA's Avatar
Digging the dash, I'd love to get a Wrangler and swap in an LSx
Old 11-15-2008, 07:46 PM
LUMPY85's Avatar
anyone notice the problem with the dash?? i did after i got it all installed and wired up. Im a machinist and i spent all the time drawing it all up and my buddy at work machined it out. no one has noticed it yet, but i know its there!!
Old 11-15-2008, 09:56 PM
ls1nova71's Avatar
Yeah, your R for race should be after neutral. You might want to fix that. If you let someone else drive it , they won't find the race gear!
Old 11-16-2008, 12:07 AM
LUMPY85's Avatar
yeah, i nearly **** myself when i seen that. i got to much time into it to fix it. they light up in the right order, me and my wife are the only that will ever drive it unless i sell it.
