04 GTO AC wiring question
I know how to wire an F body LS1 PCM to handle the AC controls, but I've been looking at the 04 GTO pinouts and don't see the pinouts I need to wire it up the F body style.
Anyone every gotten the 04 GTO to control the AC?
A/C Request
I used the PCM (2002 Camero) to control the Vintage Air A/C in my 1941 ****** / S10 / LS1. Works great, but you have to use the GM trinary switch. Put +12 on the A/C request PCM C2 pin 17 on mine and the PCM will turn on the cooling fan and compressor if the system has a proper charge. The PCM will also turn the cooling fan on high for an over pressure condition. I was pressure testing the A/C and found this out.
Bill
Bill
