What fuel rail with Vette filter/regulator
Hey guys, I was wondering if the fuel rail off my 05 LQ4 would work with the corvette fuel filter/regulator? Im pretty sure I still need to get a return style but I am just curious. BTW I will be using the truck intake as well. Let me know, thanks.
Sam
Sam
since the vette filter/regulator has a line coming out of it for the return, if you keep a fuel rail that has a return on it, you are basically going to spill fuel all over the place, so either get a regular filter assembly, or get a 99 up vette single inlet fuel rail.
The reason for the return line is so the pump flows enough fuel volume per minute to supply the engine and cool the pump with the excess fuel flow. So, use the '99 Vette filter/regulator: 3/8 fitting on inlet is supply from pump; 5/16 fitting on inlet side is return to tank and single 3/8 fitting on outlet side goes to the one-line fuel rail. The filter/regulator must have been made for swaps ....
9 Second Club/LS1TECH Sponsor
The GM number is 10299146. That's the 99 and newer Corvette filter/regulator. This should work great for your application.
You could go with an expensive Aeromotive regulator, but by the time you buy all of the needed fittings, you'll have 3-4 times as much money in it!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
