Does E38 ECM Need Oil Pressure To Run?
I have searched and asked some people with no definitive answer. Does my E38 ECM need the oil pressure input to run or not? Im not using VVT or AFM.
I want to use the valley port for my gauge and sender hookup. I am aware of the ports by the oil filter, but due to clearance, I prefer the valley.
Thanks.
Thanks.
The factory sender also helps the E38 set a DTC if there is an oil pressure loss, either momentary or continuous. Its not a bad idea to keep it for the momentary loss which you may not notice otherwise.
I use a tee piece between the factory sender on the sender port to run a regular gauge.
Cheers.
Cheers.
