Wiring done...correct fuse amps?
Well I've got the relay's wired for the fuel pump, fans(3relay's), Start, L bank inj/coils, R bank inj/coils.
The donor junkyard fusebox (nice and small) was wired so the fuses are on the battery power side of the relay's rather than after the relay's...should be ok though...correct?
For the fusing here were my thought's...please correct me if I'm off.
1. Start relay 40A
2. L bank inj/coils relay20A
3. R bank inj/coils relay20A
4. Fuel Pump relay 20A
5. Fan relay's 40A each relay
6. Trans relay 15A
Non relay items--This is how I've grouped things so far (These are ign fused not constant...except for +bat)
7. MAF/PCM 10A
8. Front o2 sensors 15A
9. + Bat power(pcm) 10A
10. TAC module 10A
11. Evap purge/vent 10A
If anyone sees anything that needs more or less or none...let me know your thoughts.
1. Start relay 40A
6. Trans relay 15A
7. MAF/PCM 10A
10. TAC module 10A
Page through all of the 99-02 schematics that I posted a few months back. I believe they have the correct fuse sizes listed.
https://ls1tech.com/forums/conversio...chematics.html
I've got the factory fuse ratings, but I've put a couple of items together differently than the factory so the amp rating won't be exactly as the factory (ie thinking about putting TAC/o2 together 20amp ok? and MAF/pcm)
