turbo LQ4 4L80E mustang build
Old 12-17-2008, 05:17 PM
feldz82's Avatar
Default turbo LQ4 4L80E mustang build
I decided to change directions with my car. The car is a 1995 Mustang GT 5 speed. I pulled the 408w I had in it and sold it. I scored a 2002 LQ4 and 4L80E tranny with harenesses for $750. I bought a QA1 4.6 k-member with a-arms for $180, 60mm jgs wastegate and 56mm BOV $625 for both, borg warner s475 turbo $550, pro products intake with rails $225. I think thats a good start for now. I still have parts to sell from my old combo. I'm gonna do a stock rebuild on the motor with a big cam and flipped manifolds running on e85.
Old 12-17-2008, 06:42 PM
ForcedInduction's Avatar
Have you seen this?
https://ls1tech.com/forums/forced-in...9-mustang.html
Maybe give you a couple ideas what Giffin Did. No 4L80 tho in this swap
Old 12-18-2008, 11:28 AM
feldz82's Avatar
that's a cool build. alot of similarities with what I'm planning. Can't wait to start mocking it up
Old 03-10-2009, 09:25 AM
feldz82's Avatar
got the motor and tranny mocked up
the turbo
the merge
Old 03-20-2009, 01:59 AM
Perf_white_gt's Avatar
subscribed so i can haz updates..
the more specific details... the more i'm gonna want to do this...
wiring harness?
will the stock gauges still work?
header options?
ODBII ability?
if you cant answer some of these its all good... i'm just looking to do something else other than keep this h/c 2v gt..
Old 04-19-2009, 07:56 PM
feldz82's Avatar
I thought i would update this thread. since my last post I've got a few things accomplished. I've repinned my factory truck harness. I was gonna run my megasquirt I had laying around, but my buddy talked me into running the stock pcm, so thats the route i'm going.
I've got the turbo mocked up
I had some millwrights at my work make me up some exhaust manifold flanges.
I finished up the crossover pipe on friday
Old 04-19-2009, 09:50 PM
Capown's Avatar
damn!! Why can't I ever find a motor and tranny for cheap?!? Salvage yard here is like up full price like its new, 4L80 1200 motor 2300 WTF!!
Old 04-20-2009, 10:08 AM
feldz82's Avatar
For the price I got them for, makes me wonder why I ever messed with Ford stuff
Old 04-20-2009, 01:40 PM
1989k1500's Avatar
Cant wait to see this thing done, going to be an animal!
x2. Id kill for a 750 dollar 6.0/80e. Then Id have a 6.0 for my 89 and a 80e for my 01.
Old 04-21-2009, 12:34 AM
BTP
BTP's Avatar
The more specific details... The more i'm gonna want to do this...
Wiring harness?
Will the stock gauges still work?
Header options?
Odbii ability?
bump!
Old 04-21-2009, 02:01 AM
letsrunem's Avatar
wiring harness?
Modify the one that comes with the motor. Very easy, just time consuming. Lots of threads on this.
You can get them to work, I went with all Autometer though.
header options?
Kooks makes swap headers $$$ though. Take 351W headers, cut off the flanges and weld on LS1 flanges. Do a search.
ODBII ability?
Wire in an OBDII plug in under the dash. Power wire, 2 grounds, and serial data wire from the PCM, very simple.
Old 04-21-2009, 08:45 AM
feldz82's Avatar
you can also get a speartech harness. instead of headers, you can flip some truck mani's and go turbo. autometer gauges for me.
Old 04-21-2009, 09:09 AM
BlackTA96's Avatar
What are yall doin for motor mounts??
Old 04-21-2009, 09:45 AM
feldz82's Avatar
solid 4.6 mounts and adapter plates
Old 07-12-2009, 10:49 AM
brandon1566's Avatar
Did you have any trouble fitting the 4l80e in the tranny tunnle?
I know everyone that does this swaps k members also, are their any issues with using the stock k member and just modifying the mounts?
Old 07-12-2009, 11:22 AM
73 nova guy's Avatar
what waste gate are you using there it looks alot like the one my buddy is using on his diesel.
Old 07-13-2009, 01:12 AM
mulletnotch's Avatar
LMAO I couldn't agree more!!
Old 07-13-2009, 08:00 AM
feldz82's Avatar
The 4l80e fits great. I didn't have to use a bfh to get it to fit. The motor sits low and close to the firewall. As far as k members I'm sure the stock ones would work, but the tubulars give you more clearance for headers. Plus i got it for pretty cheap.
Old 07-13-2009, 08:02 AM
feldz82's Avatar
It's a 60mm jgs wastegate. heard good things about them.
Old 07-13-2009, 08:23 AM
feldz82's Avatar
Thought I would update my thread. Got some time recently to work on the car. I welded in some subframe connectors. I welded my trans xmember mounts to the connectors and started the x member which is gonna be some square tubing.
I also started on the downpipe. I was gonna dump it in front of the front pass tire but decided I'm gonna run a single 4" back and Y it off and reuse my tailpipes. I will snap some photos after work and post them up as soon as i can.
Quick Reply: turbo LQ4 4L80E mustang build
