Mini fuel system is done! (pics)
Went with the return on top of the tank, no tube inside the tank since I didn't want it to vibrate and crack off later. There is a baffle inside the tank that will keep the return and the sump separate.
single digit dreamer
that looks great.
i would be a little worried about pluging up that black thing. we didn't run a pre filter on our fairmont project and ran a very small fuel filter after the pump. we pluged up the pump with junk more than once and were always cleaning that small post filter. i dont know where the junk came from but it got in there somehow. from now on we are running a large prefilter.
that looks great.
The before pump filter is just to screen out the big pieces to protect the pump.
I have alway read that you don't want too fine of a filter before the pump. Just something to keep the big pieces from damaging the pump. That looks like a Mallory unit with the screen inside. Should be really easy to clean out.
It is the after pump filter that protects the injectors/carb. The after pump filter can afford a bigger pressure drop than before pump filter.
