oil cooler lines on a 6.0
Right above the oil filter on the block,just wondering can you make a plate and cover up that provision up or do you got to run the oil cooler lines?AND WHERE DOES THE CRANK TRIGGER PLUG IN AT...
The crank sensor is behind the starter. And I'm pretty sure you can just remove the oil cooler and put the filter directly on the oil pan. Oh wait, I was thinking old school type oil cooler, bczee is right about the adapter part!
