HELP-Building LS1/TH350 91 Mustang GT
Building a Carbed LS1 th350 91 Mustang GT car was a manual... it has 3.73 gears in it.
What we have so far...
224 cam 581/581
port 317 heads 62cc
2001 Ls1 block arp rod bolts
C5 Manifolds
RPM carb manifold
holley750 carb
MSD computer
TH350
crank pulley
What we still need...
starter... alt... water pump... stall converter...K-member...oil pan ...pick up...flexplate..spacer...coil packs...valve covers
what oil pan and k-member are you runnig on these FOX mustangs?
Me and a buddy are putting together a LS1 with a th350 and 3500 stall... 224 cam 581/581 with RPM manifold and carb.
I need to get a oil pan? Will a Truck pan work?
I know we can use a after market K-MEMBER for about 250.00
But I have heard you can weld up mounts? Or use a 96-99 4.6 K-member?
Anybody have any input? Thanks
224 cam 581/581
port 317 heads 62cc
C5 Manifolds
RPM carb manifold
holley750 carb
MSD computer
TH350
crank pulley
https://ls1tech.com/forums/texas-mem...red-notch.html
Hey man. Look at my build in progress. It might help a little. If you have any questions let me know.
