Carb'd & front mount Distributor, fox swap is ALIVE
I have fought the good fight and won. FInally after countless hours working/sorting through setbacks and bad weather my LSX powered notch is alive. Here are some update pics and a link to a video
http://www.youtube.com/watch?v=mMRZJfpsixk
More detail can be found on my blog
http://www.mylrs.com/blogs/lrs/archi...live-quot.aspx
The wire you see hanging is the coil wire for the non-working coil. I had to bypass it right quick to get it running. As for the ford blue. I'm planning on building adapters for Ford valve covers to bolt in place of the LS units. then it will really look like its a SBF.
From the pictures it looks like you are running the zex plate system. If that is what it looks like, how do you like it? I have been wanting to try it for a while, but couldn't find any feed back on it.
honestly I just cranked it last weekend and haven't even put the rest of the N2O on it. From all the feedback I've hear its a great plate but the rest of the system isn't so desireable. That is why I'm piecing mine together. Taking the best from all areas and making it work. the only ZEX piece I'm using is the plate.
When you buy the zex plate it comes with a jet reference guide for all the other kits that are out there to tell you which ones to use with whichever kit you are using
This is what I bought
http://www.latemodelrestoration.com/...0%201&comp=LRS
