Boxster LS1 swap: Ideas needed plz
Old 03-30-2010, 05:04 PM
  #41
Tainted's Avatar
keep the torque and fix the problem by getting something that will hold the power. I researched trannys a while back for a ultima GTR and they sue the porsche trannys that can hold oodles of power. you may try their website and look at the vendors for those trannys that are already built. i remember seeing some that could hold over 700hp for bout 3k plus core
Old 03-30-2010, 06:33 PM
  #42
GIGAPUNK's Avatar
Originally Posted by wulfgang
Hey, it's still going? That's great, I just emailed you last night. Any fitment issues? Eric mentioned he has an adapter plate, so I know that the starter issue has been solved. I think I can handle any mounting issues will a bit of steel and some welding, but what about the pulleys? Do they hit the firewall?
I found out yesterday that the G86.20 tranny (from the Boxster S) is rated for just 280 ft-lb input torque (Getrag spec). That is not good. I had read that this is the same gearbox as the 996TT (with swapped ring gear orientation), but that is definitely not true. The TT uses a Getrag with a much higher torque rating.
So I was thinking about destroking the LS1 to reduce the torque on the G86 input shaft. Then upgrade the valve springs to get to 7200 rpm redline (which is the same as Boxster S) to recoup some of the lost hp caused by the shorter stroke. But then the project price goes up and you miss out on some of that monster torque. I'd like to keep it around $3-4k overall because that's what I'd expect to get for my 3.2 L after pulling it.
Don't read too much into those stock torque ratings. The t56 is "rated" at 400 lb ft, and everyone knows that they last to 700 lb ft just fine. There's no need to destroke.
Old 03-31-2010, 03:39 AM
  #43
zerosoul914's Avatar
Easy: if your on a budget, learn not to do any sort of burnouts or drag style launches and your tranny will last a long time. Believe me lots of 914 guys use their STOCK 901's on SBC's for years because they don't abuse their trannys. Now if you want to spend cash and do all that fun stuff start looking into the flipped G50 transmissions. If the 901 (which was rated at under 100 lb/ft) can handle 300lb/ft from a SBC, then the G86 can handle stock LS1 power levels just fine as long as you don't abuse the thing.
Old 04-01-2010, 08:38 PM
  #44
wulfgang's Avatar
Not sure how this would work. I just went out and took some measurements. The LS1 fits easily in height and width, but it seems to be at least 5" longer than the Porsche M96, which is just 20" long. The pulleys on the M96 are already very close to the firewall. Thus, there are four possible solutions:
1. Move the firewall forward (not good, since a 6' driver is already pretty close to the steering wheel).
2. Move the engine back (not good since this would put the output flanges on the tranny 5" further back, which means new, longer axles would be at a less-than-ideal angle).
3. Get a shorter tranny? No idea if that's possible.
4. Maybe use the LS1 from a FWD application?
Old 04-01-2010, 11:06 PM
  #45
txcarbuilder's Avatar
4.) The front parts from the LS4 can be installed on the other LS engines if necessary. This will shorten the engine about 2 inches. The other option would be to run an electric water pump.
Old 04-02-2010, 02:47 PM
  #46
Isolde's Avatar
The LS4 has a shorter snout on the crank. In fact, the crank is shorter on both ends. That's why the LS4 can be 2" shorter than any other LS. And the LS4 block can be bored to 5.7L, so you can have an LS6 in a smaller package. If you're doing a transverse install, you should get on some other forums. The best info is probably going to be on www.fiero.nl Mostly from Rickady88GT and blckcfy, If I'm remembering correctly the spelling of their user names.
You should do this swap. When I had my '95 Z28 conv, w/ A4 and econo gearing, I beat a Boxster, despite me having a heavy passenger.
Old 04-02-2010, 09:36 PM
  #47
I'm curious to see what DirtyZ does with his 996TT/LS1 swap since he'll have the same problem just in reverse
Old 04-02-2010, 10:52 PM
  #48
Andy1's Avatar
You can destroke the LS1 by putting in a 4.8 crank and rods, but then you'd need custom pistons to get back the compression ratio; then balance the assembly. That in itself wouldn't be too expensive. That would get you something like 312 cu. in. if I recall correctly.
Though I can't quite get an exact measurement with the motor in the car, my LS1 with LS6 dampener and LS2 water pump measures about 25". If the LS4 stuff takes off another 2", that gets you down to 23" but I suspect there'd still be no room for the accessoriy drive.
I'm considering a BMW or a Boxster for my next LSx project, so I look to this one with keen interest. Maybe I'll pay a visit one of these days to the guy (BR) that's doing this one, since he's only an hour from me.
Andy1
Old 04-03-2010, 01:49 AM
  #49
1dirtyZ's Avatar
a wise man once said " fear not the hacksaw blade "
seriously , can't you cut out a recess (sp?) where the accesory drive will go and then fab up a cover? it might bulge out a few inches but i bet you it won't be noticable once you get it covered up . ( unless there is something important in thea area and you can't cut it )
Old 04-03-2010, 07:15 AM
  #50
Isolde's Avatar
Again, the Fiero world has your solutions. And the LS4 accessories hug the block far more than any other LS bracketry if you're interested.
Old 04-03-2010, 11:59 AM
  #51
wulfgang's Avatar
Heh... there is zero room behind the seats. They can just barely recline with a 6' driver. Then there's the center console that butts up against the firewall. So that would have to be cut and still somehow made to look nice.
...and then there's an adapter plate that is going to add another inch or so.
I've been looking around, and it seems like the LS1 could be made to be 24-25" long, but that's still 4" too long!
@Isolde: this is an S. Your Z28 would have a harder time beating it in a straight line, but then again, this will be a commuter/track car. I do not intend to take it to the strip, ever. Instead, it needs to sustain high revs and high-g cornering for 20 minute sessions without overheating or getting oil starved.
@zerosoul914: From the pics I have seen, the 996 should be able to fit an LS1. There seems to be a several inches back there where the airbox sits that could be used.
Looks like the VH45 is a bit shorter than the LS1 (the extra width of the DOHC isn't a problem since the M96 is 28" wide), but that's another forum...
Old 04-03-2010, 05:46 PM
  #52
1dirtyZ's Avatar
How about moving the tranny a bit back ?
i might go that route on my 996 if need be
i don't know about your case , but if there is some space behind the tranny to move it back you can mount the engine as close as you can to the front bulkhead , slap on the adapter and the tranny , then fab a new trans mount to work with the new location .
i'm sure the change would not affect the shifting cables or the cv joints much .
can you get us some pics of what space you have to work with ?
Old 04-03-2010, 08:21 PM
  #53
Different engine configurations bud. Boxster = mid-engine rwd. The problem is that the stock axles are already at a slight angle, so I'm not entirely sure what my guy is planning to do. Shorter accessories is one thing but we also have to make up for the adapter plate as well.
Old 04-03-2010, 08:22 PM
  #54
wulfgang's Avatar
I wouldn't be worried about shifting cables, but moving the gearbox won't work, as that will cause the output shafts to get too close to the control arms. There isn't 5" there, for sure. In addition, the suspension pickups are also the gearbox mounts (which how all cars should be). Moving the gearbox mounts pretty much requires moving the suspension bits, which is of course waaaay too much work.
I don't have pics of my car at the moment, but here are some from google. First, a bottom view of the gearbox here.
And the top view of the engine here. The front is on the left, gearbox on the right. You can see an accessory pulley off to the left... it really is a short engine! The red metal on the left side of the pic is the top of the firewall. The tan colored leather/carpet is the interior of the car.
Old 04-04-2010, 01:26 AM
  #55
1dirtyZ's Avatar
ok , i might be going off on a limb here , but after seeing this pic i beleive it is easy to do!
look at how the transmission has a three hole bracket on each side ( look on the pass. side , the rearmost control arm points to it) , well attatched to that bracket is another bracket (black one ) that goes to the transmission mount ( wich looks alot like 996 engine mounts) . the key ( according to my limited number of grey cells ) is in making a new set of these (black) brackets where they curve backwards in a way that mounts the tranny further back. now i know from looking at these pictures that there is a ton of room behind the tranny where the muffler is, but like you mentioned above the cv axles might be an issue . can you get a pic just like the second one ( side shot of the rear axle) but without the rotor being in the way ?
thanks for the pics by the way !
Old 04-04-2010, 01:48 AM
  #56
1dirtyZ's Avatar
here's a better pic of the brackets :
and i know this might get the project out or its intended budget , but have you looked into the audi transmissions?
the axle flanges are much closer to the engine than in a porsche .
could be a solution to the CV placement issue ?
here is one example :
Old 04-04-2010, 10:38 AM
  #57
Tainted's Avatar
ok how about this idea...
instead of moving the firewall forward what about moving everything back and mounting some of the thigns into the rear trunk area...?or hell what about even turning the motor sideways like in a FWD application and using a FWD tranny of some kind?
Old 04-04-2010, 04:19 PM
  #58
1dirtyZ's Avatar
is it just me or am i seeing an epic space that is just begging for a twin turbo setup?!
Old 04-08-2010, 10:18 AM
  #59
mkingham's Avatar
Default how to loose the 5 inches
Hi Ethan,
What is the horizontal distance between the front of the boxster tranny where it mounts to the engine) and the center of the output shaft flange? I used a 'short' 930 tranny on my LS6 swap into a 911. The 930 is a large four speed capable of about 600 ft-lbs of touque. In 1976/77 they made a short version that was 2 inches shorter than the later 930's. It is also shorter than the G50 that came even later.
If you will post that measurement, I'll measure my tranny. This combo may buy you a few inches without having to shift your axels.
Good luck and please keep this project going. There is a lot of interest in this type of conversion! I used to own a 2002 Boxster S. I loved the car, but the 252 hp was a bit anemic.
Mike
Old 04-09-2010, 02:40 AM
  #60
Originally Posted by mkingham
Hi Ethan,
Mike
Mike I appreciate the help, however the car and tranny are in the hands of the builder. I believe Mr. Martin can clarify the measurements for the trannys. My own car will be used as an entry level performer show casing full amenities and electronics. I'm sure there are plans in the future for more radical setups where a G50 will come into play.
The car's themselves have phenomenal chassis and suspension development already into them. There's a well known boxster owner in the forums who goes by "grantsfo" that has shown what these cars are capable off. His stripped out self-made "spyder" received the top time of the day at a GGR autoX event and tore up the previously dominant 914s
Quick Reply: Boxster LS1 swap: Ideas needed plz
