Could you do a 4 eye LS1 EFI swap?
you could always get a tank ot of a nwer one so it would have apump in it, if you didnt want to mount an external pump. other than that its the same. you have to change the fuel lines either way cuz all those stang had the wimpy 5/16 lines so it doesnt matter wich car in that respect.
The tank is the same from 79-91, the internal pump/pickup carrier is different. Go to http://www.50resto.com and order the correct sending unit/pump bracket for the latermodel car, and you will be good to go. Or just sump your fuel tank for $50.
i used a sumped tank with an external aeromotive pump, but you can use a tank from an 87-93 foxbody. here's a link to my build: https://ls1tech.com/forums/conversio...p-project.html
