84 camaro lsx swap
Old 02-18-2009, 05:29 PM
xpndbl3's Avatar
Default 84 camaro lsx swap
Well figured I haven't posted any pics yet of my swap. So here's a few of the car and the drivetrain.
ugly yellow side marker and faded front turn signals are both gone now with clear ebay housings that look 100x's better.
drivers side header completed that I hand made out of a ls1 header flange and some hooker 1 3/4" u-bends
here's your basic baby cam only engine with msd 6010 box and a carb on top.
Tranny is a TH350 and have a moser 9" out back. Tires are 28" M/T skinnies up front and 28x12.50 ET streets out back.
Old 02-18-2009, 07:38 PM
holley505's Avatar
I Love IT !! Cool Car ... Awesome Motor.
I was running ... 11.7 with my 84 camaro gen I sbc with 175 shot.
I was running 12.00 @ 114 with a N/A ls1 in a C3 vette with Th350 and 3.36 gear
Old 02-20-2009, 08:21 PM
xpndbl3's Avatar
finally finished both sides today and painted them in VHT header paint.
drivers side installed from behind
both headers installed....only .5" lower than the oil pan, should be perfect for ground clearance.
both headers from behind
passenger side header, now this is what I call tucked perfectly. .25" clearance all around the collector flange.
Old 02-20-2009, 11:18 PM
91ZLS6's Avatar
like i said on tgo...
Old 02-20-2009, 11:22 PM
luckyhenriksen's Avatar
lookin sweet. I like the look of the cowl hood
Old 02-21-2009, 07:34 AM
turbo.trex's Avatar
That's a clean start
Old 02-21-2009, 08:09 AM
sujomatt's Avatar
I already am loving your car, great job so far! Let me know if u ever sell it
Old 02-21-2009, 09:15 AM
xpndbl3's Avatar
I would never get remotely close out of the car for what I've already sunk into it otherwise I'd be rocking a 70 nova SS by now.
Old 02-21-2009, 09:25 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Keep 'er nice under the hood and I'll check with Camaro Performers about a future shot.
Old 02-21-2009, 01:44 PM
xpndbl3's Avatar
Ya once it's all mocked up I'll be tearing it back down to clean up the engine bay to make it look perfect. Hiding all these wires will be fun no doubt.
Old 03-08-2009, 11:27 AM
xpndbl3's Avatar
Finally fired it up the other day, still have lots ahead to finish but thankfully I didn't have any issues with the msd box like others have had. New battery, 0 gauge wire throughout and a new starter probably didn't hurt either
Old 03-08-2009, 01:14 PM
holley505's Avatar
What cam and Heads you running on that car?
Old 03-08-2009, 02:00 PM
boss79z's Avatar
Nice work on your headers. Must be nice to be able to build things to your specs. I was wondering if the hawk headers would work with your setup? Beautiful car.
Old 03-09-2009, 01:34 AM
xpndbl3's Avatar
stock heads off the motor and a 224 cam IIRC.
ya sure the hawk headers would work if I wanted to spend close to a grand with shipping for headers that may or may not tuck up as high as the ones I made since I moved the motor back and down slightly. I have under $300 in these headers, so I'm happy with my investment and fitment. If 1 7/8" headers become available then I may sell these off for them.
Old 03-09-2009, 03:56 AM
TPI TERROR's Avatar
nice build!>
Old 03-09-2009, 12:18 PM
WayFast84's Avatar
What did you do for a fuel pump? This is pretty much the same thing I want to do but I want to use an LM7. What did you use for the motor mounts?
Old 03-09-2009, 12:35 PM
NemeSS's Avatar
very nice! what trans?
Old 03-09-2009, 02:47 PM
boss79z's Avatar
I completely understand about saving the extra money. Great work and on a beautiful car.
Old 03-09-2009, 04:21 PM
xpndbl3's Avatar
i have a magnafuel pump and regulator from all my other carb projects. Motor mounts I bought the trans dapt conversion plates but they were WAY off so I had to cut and weld up my moroso solid mounts to make them work. Probably were off at least 2" from where the motor ended up.
TH350 long tailshaft with a big stall, I have a TH400 waiting in the garage fresh in case I burn up the TH350.
Quick Reply: 84 camaro lsx swap
