Carbed setup guys, what tranny are you running? - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 03-04-2009, 07:07 PM   #1
Default Carbed setup guys, what tranny are you running?
I would love to get a T56, but I think the cost would put me over my budget quite a bit. After researching going with a 4L60E, it seems it would be just as expensive due to having to buy the $700 TCI TCU.
Do I just bite the bullet and start savings my pennies for a T56, or is there a way to put a tranny behind a 6.0 that won't cost $1500-2000?
g6t6o is offline   Reply With Quote
Old 03-04-2009, 07:11 PM   #2
xpndbl3's Avatar
TH350 or TH400
xpndbl3 is offline   Reply With Quote
Old 03-04-2009, 07:37 PM   #3
luckyhenriksen's Avatar
I am using a rebuilt TH400 with a 3500 ACC Stall and hopefully a nice shift kit
I think if you are going carb you are going for simplicity or raw power, so the old schools trannies are used. When you want drivability you keep the EFI and use a late model overdrive. I guess you could always use a 700R4 or a 2004R
luckyhenriksen is offline   Reply With Quote
Old 03-04-2009, 09:11 PM   #4
S10xGN's Avatar
200R4 here, dual-fed with billet forward drum (among other nice mods for longevity) and a VIG 3600 stall. Built by "JakeShoe" from Sanger, TX.
Russ
S10xGN is online now   Reply With Quote
Old 03-05-2009, 06:31 AM   #5
forcd ind's Avatar
i guess you have to fig out if you want overdrive or not-if not, a turbo 350 or 400 is ideal
if overdrive, then whether computer operated or not
the 200R seems to be a better choice over a 700R, then its a choice of a 4l60e or 4l80e, diff in weight and size
i started out with a switch/pitch, old school dual stall turbo 400, but really wanted overdrive, so i got a 4l80e, made it man. shift to save buying a computer, didnt like going racheting thru 3 gears every time i stopped, so i got another valve body, got a deal on a Compushift controller(easy to use/setup) and love it-65 MPH, 2K RPM, sure quites down the Flowmasters, lol
ya, i spent a lot of money, in the long run a 350 or 400 with a good converter would have been wallet friendly-again, use, horsepower, first gear ratio, etc comes into play-im not a trans tech, but i do my own stuff, so i save a ton of bucks that way, offsets the parts price
if i were starting from scratch right now, 200R, no computer, lighter, lots of upgrade parts, someone even advertises it for a 572 B/B engine, so they can be made tough
forcd ind is offline   Reply With Quote
Old 03-05-2009, 06:52 AM   #6
LS1MCSS's Avatar
I am running a 200-4R right now, but if it goes south, I'll probably switch to a manual valve body 4L80. I seldom ever drive my car, so the gear changes won't be a problem for me.
LS1MCSS is offline   Reply With Quote
Old 03-05-2009, 07:17 AM   #7
prochargedchevyi's Avatar
For street purposes, I used a 200r4 from a Buick Grand National. Go check out a GN forum and they usually have used ones for sale pretty cheap.
prochargedchevyi is offline   Reply With Quote
Old 03-05-2009, 07:21 AM   #8
SMAX's Avatar
th400 with a 4k stall
SMAX is offline   Reply With Quote
Old 03-05-2009, 10:03 AM   #9
rojs234's Avatar
Mine is Stage 3 200-4R by Bowtie Overddrive with a Vigilanti 3000 Lockup convertor.
rojs234 is offline   Reply With Quote
Old 03-05-2009, 10:39 AM   #10
billyflantos's Avatar
turbo 350 man. valve body jw bell housing and turbo action 8inch conv(and by the way the bolts on the plate at the back of the block does not clear jw bellhousing grinding is a must and easy to do 10 minute fix)
billyflantos is offline   Reply With Quote
Old 03-05-2009, 10:47 AM   #11
Quote:
if you go to turbobuick.com to find a trans. make sure it has br-f code on the yellow plate on the pass. side of the trans. to be a true turbobuick trans(have better valve body)and it's alot more desireable....
Old 03-05-2009, 11:04 AM   #12
I am running a TH350 with 3000 stall Non locking.
Just swapped to a 3500 stall. No new times yet.
You need to purchase adapter/spacer (about 50 bucks) and it your choice to swap flywheels. many use longer flywheel bolts. If you upgrade flywheel go with HUGHES about 120 dollars over TCI (TCI is pricey)
holley505 is offline   Reply With Quote
Old 03-05-2009, 08:31 PM   #13
topher455's Avatar
fully built th400 with a loose 3100ish converter and 3.08 rear gears
topher455 is offline   Reply With Quote
Old 03-06-2009, 09:38 AM   #14
LS_STANG's Avatar
I just went with a th 350 but I do have a 200r4 that I never put in with a 3000 stall for sale. The stall was never used. for 400 obo
LS_STANG is offline   Reply With Quote
Old 03-06-2009, 01:20 PM   #15
djsanchez2's Avatar
I have a TH400 for mine with a yank converter. I also have a back up Powerglide in case i dont like the 400. I'm still in the build process so i have yet to even drive my nova
djsanchez2 is offline   Reply With Quote
Old 03-06-2009, 02:02 PM   #16
NemeSS's Avatar
almost same setup,
full built th350
4k stall anti ballon plate
hughes flexplate and 6.0 spacer with arp bolts
NemeSS is offline   Reply With Quote
Old 03-06-2009, 03:20 PM   #17
topher455's Avatar
I have the tci plate in mine and it was expensive but I can say it is one HELL of a part. I was very impressed with the quality and it came with a spacer. I didnt use it though since my edge converter was custom built with a changeable pilot. Not dissing the hughes just giving my experience with the tci piece.
Old 03-06-2009, 03:24 PM   #18
What all is involved as far as adapters to mate the 5.3 or 6.0 to a Th-350?
Is it a different converter, different flexplate, or some sort of adaptor?
And, any links to where to get the parts?
I have a possible chance to get a 40,000 mile 5.3L, I know that I will have to either make motor mounts or purchase them, as well as make the harness a standalone, but I am at a loss as to what to do about mating the motor to the turbo 350 trans I have.
Oh, forgot, this would all be going into a 70 camaro.
victor3ranger is offline   Reply With Quote
Old 03-06-2009, 05:24 PM   #19
summit has the adaptor for 45 bucks and all you have to do is oblong the flex plate to fit the conv. but some 6.0's already come with the spacer.
Old 03-06-2009, 07:42 PM   #20
bygblok's Avatar
I originally bought a used 6.0 flexplate with the spacer and bolts off of here to use with my TH350 but ended up getting the TCI plate instead. Just felt better about it. I'll sell the flat 6.0 plate now if anyone wants it.
bygblok is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
