LSX intot LTx info needed
ok I am looking to swap a LSX setup into a 95 bird
As far as motors will a C5 setup work or will i have problems with the acceseries and oil pan etc. and trans is different?
The accessories and oil pan will both be problems and will not fit. Your other probelm is the harness will not work because the tranny is mounted in the back of the C5. You can use the longblock, but that's about it.
Re'
Re'
