Pin out for MLPS
Pin out for MLPS
[ATTACH][/ATTACH]I tried posting this on the automatic trans. section and got no feed back, I don't know where to post this so I will try here. I've done searches trying to find this pin out but to no avail. I have a LS1 in a 69 Camaro (4L60E) I am using a Corvette C5 shifter, so I am using this sensor for reverse lights and neutral s/s. Called my parts guy at dealership, he didn't know, I figured one of you would. Here's a pic of the car and the sensor, thanks Shawn
I know this is a "first generation" MLPS. This is all I have, I know it won't help, but maybe someone else will see it and add the right info. Is it possible for you to switch to the newer one?
https://ls1tech.com/forums/conversio...g-pin-out.html
Park/Neutral Position (PNP) Switch Connector C1
Connector Part Information
12129840
7-Way F Metri-Pack 150/280 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A
Not Used
B
LT GRN
275
Transmission Mounted Neutral Safety Switch Output
C
PNK
839
Fuse Output - Ignition 1 - Type III Fuse
D
BLK/WHT
451
Engine Control Module Ground
E
PPL
806
Fuse Output - Crank - Type III Fuse
F
GRY
1524
Backup Lamp Feed - Monitored
G
PPL/WHT
1035
Starter Relay Feed - Coil
Park/Neutral Position (PNP) Switch Connector C2
12191757
4-Way F Metri-Pack 150 Series, Sealed (NAT)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
771
Transmission Position Switch - Bit 1
B
GRY
773
Transmission Position Switch - Bit 3
C
WHT
776
Transmission Position Switch - Parity Bit
D
YEL
772
Transmission Position Switch - Bit 2
12129840
Pin
Wire Color
Circuit No.
Function
A
Not Used
B
LT GRN
275
C
PNK
839
D
BLK/WHT
451
E
PPL
806
F
GRY
1524
G
PPL/WHT
1035
12191757
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
771
B
GRY
773
C
WHT
776
D
YEL
772
Thank you!
Just was I was looking for, I tracked down a link from your post^^^^^^ came up w/this http://www.justanswer.com/questions/...2500-hd-diesel and the 2 put together helped get the info I needed, Thank you!!! Shawn
I've got this same 4L60e MPLS switch, would I need to use this if I'm retaining the stock P/N switch inside my 1976 Camaro?
Is there anything I need to connect to my inside P/N switch for the PCM to operate correctly?
