fried fuel pump relay?
I was cruising down the street and all of a sudden my fuel pump died with no warning. Turned out that the terminal on the relay had gotten so hot that it melted the plastic around it and was no longer carrying voltage to the pump. What would cause this to happen? I checked for a short and could not find one. I replaced the relay and the melted plug and have driven about 300 miles with no problems...Any ideas?
9 Second Club/LS1TECH Sponsor
Re: fried fuel pump relay?
Don't know for sure without checking it, but 9 times out of 10 that kind of damage is caused by a loose or bad connection right at the point of damage. The loose connection results in high resistance right there, which generates heat. It becomes a viscious circle of higher resistance / more heat, until something gives way or burns up. If the connection is properly repaired you should have no more trouble.
That leaves a 1 in 10 chance that something else is intermittently shorting or causing high current draw, but I doubt it.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
Thanks John, i'll buy your 9 times out of ten, cuz your right 10 times out of 10! I still cant believe those O2 sensors were crossed!!!!
