$100 tothe first person to.....
i will give $100 to the first person to make me a wiring diagram of a 2000 LS1 out of a firebird and put it in laymans terms becuase my head hurts and is spinning from all the different diagrams. Im putting the LS1 in a Honda S2000 with only the basics, fuel,speedometer,oil pressure,water temp,tach,fans...I have got rid of secondary O2 and air pump,fuel tank pressure,vats...
when i did my harness this line helped me the most.
in a nutshell... give ignition power to the pink wires, constant power to the orange ones, take off VATS, and it runs.
cut out all the connectors you dont need(rear 02, smog), connect the black wires to a ground.
FAQ's are your friend.
