Intake ducting elbows
Is there anyplace like home depot/ace/ect that sells intake 90 degree bends like the one from jagsthatrun.com?
The ones Lowes sell will not work for me as they're not a tight enough bend (not to mention the bulged ends look tacky).
I ordered the wrong part from Jagsthatrun by accident because I forgot they rate the hose at OD instead of ID so the 3" adapter I bought might have 2" ID if I'm lucky...no way that's going over the MAF.
http://intakehoses.com/Merchant2/mer...ory_Code=R9DEN
I think this is the elbow you're looking for. It's a 4" to 3.5" reducer elbow so should be perfect for connecting throttle body to the MAF sensor.
http://www.stikiller.com/product.php...cat=311&page=1
THE BEST MANDREL TUBING EVER! hate to jock a non-sponser but they have beautiful polished angles and straight. i will post my pics...took me a month to find them
LS1TECH Sponsor
We have the Spectre 4" 90 degree silicone elbows in stock. it is a super tight radius, in fact, the inner bend just clears the throttle body flange!!! If you get a Spectre air cleaner, it comes with the right bushings to make it the MAF fit in the 4", or you can get an adapter. Give Tim a call today to get one ordered.
thanks guys, I was just hoping someone knew of a chain store I could get one local, I need a 3.5" to 3.5" just to do some work on cold air, I just ordered the wrong part
I'll just exchange it for the right one and wait I suppose...I need to not order parts late at night when I'm not thinking properly
I already have a 90 bend from the tb to maf and a filter, I just want another 90 to send the filter down where I'm going to make a scoop for cold air
