99-00 6-speed corvette ls1 wiring questions
Ok, so I have the pinouts for the PCM, but I don't have the pinouts for the two round connectors that connect the PCM to the trans, BCM, etc.
I used my multimeter to trace a lot of them, but some I couldn't get (bad connection? maybe my probe just didn't touch right?) Here's what I have. Can someone fill in the blanks?
Also, what are all the pink (and other ones I am missing) wires going to the engine relay box?
Also, the MIL and some other things don't even go to the connectors, but the vette IPC has pins for them. Does the BCM get the tach, 1-4 shift light, and MIL from the serial data line and then send it to the IPC? If so, why would the PCM have an output? For mechanics/aftermarket?
Thanks for any help, I really appreciate it. I'll post pics of my progress in a bit. Most of it isn't much to see though...
'00 vette ls1 (originally w/auto). The harness is from a '99 vette ls1 w/t56. It's mated to an fbody t56 (I've been told I need to program this PCM to use the fbody vss). I'm keeping the vette DBW and instrument panel (and I guess dealing with the error codes?).
Thanks for any help you can offer.
Thanks so much. That covers the first connector (male blue).
Do you have the same sheet for the second one (female orange)?
Also, where does the IPC get info for
MIL (BRN/WHT) RED PIN 46
TACH (WHT) RED PIN 10
SHIFT LIGHT (WHT) RED PIN 47
Is all this info carried by the serial line and then converted by the BCM or something? It strikes me as odd that the PCM has outputs for them, the IPC has inputs for them, but there are no connectors that include them.
