Stock LS2 and Procharger in my Ultima
Old 03-28-2009, 04:26 PM
ultimaboy's Avatar
Default Stock LS2 and Procharger in my Ultima
Hi Guys
Im about to start fitting a LS2 into my Ultima (mid engine car) i also plan to fit a D1sc Procharger to the stock engine.
What size injectors do you think i will need??
Is there anywhere i can get hold of a loom that will be ok for my application??
I also need to purchase some sensors and a ECM (e38 i believe), 2 bar map, cam/crank, tps etc etc is there any good companies in the US for these??
im sorry for all the questions but we have very little availability for LS parts in the UK
thanks Kyle
Old 03-28-2009, 08:03 PM
jomomma's Avatar
60lb injectors should be plenty. ive seen guys making over 700rwhp with them. how much boost/ power do you plan on making? are you going to use a meth injection kit with it? lsxtune.com has different connectors that you might need.
Old 03-29-2009, 04:29 PM
ultimaboy's Avatar
thanks
i will only be using a stock motor and running about 8 psi for around 600 crank BHP. I will just be running air to air intercooling?? Is Lsx tune a good company??
Old 03-29-2009, 07:45 PM
jomomma's Avatar
@ 8psi 60lb injectors will be more than enough! my procharged truck probably wouldnt be running without the help of steve @lsxtune! great guy to deal with.
