Oil gauge for 3rd gen F body/ LS1 swap
Old 04-02-2009, 11:22 AM
4SFEDSS's Avatar
Default Oil gauge for 3rd gen F body/ LS1 swap
I was wondering if the factory 6.0/LSX oil pressure sensor will be accurate with the factory 0-60 gauge on a 91 Z. I've heard of people saying its accurate with the 0-80 gauge but not sure about mine. I have an adapter to use the original sensor but I think it would look cleaner to use the LSX one. If you have any experience with this let me know please. Thanks
Old 04-03-2009, 11:30 AM
4SFEDSS's Avatar
Anybody?
Old 04-03-2009, 12:43 PM
MaxxMitchell's Avatar
I never tried using the original LS1 sender, as I had read it would not work. I instead took the fitting off that is above the oil fiter, tapped it with 1/8 NPT and put my sender there.
Old 04-03-2009, 01:33 PM
NemeSS's Avatar
i use a adapter that allows u to use conventional sbc sensors. for water temp and oil psi for use with autometer gages, etc.
let me go find the part #'s
Old 04-03-2009, 03:38 PM
andrew69_04's Avatar
from all the reading i have done from people that have tried, it works fine. only problem you will run into is lsx motors run 40-80psi of oil pressure, so using the stock 0-60 guage, your psi will be maxing out the guage every time you hit the gas.
Most people think it wont work since the newer clusters are controlled by the ECM. the oil pressure guage runs right off the sensor on LSX motors, it does not run through the ECM.
Old 04-03-2009, 04:50 PM
MeanYellowZ's Avatar
+1 for a stock LS1 sender running the factory gauge without problem
Old 04-06-2009, 11:35 AM
4SFEDSS's Avatar
Does anyone know which wire at the bulkhead connector would be for the volt gauge. I think it might be the brown wire but im not sure.
Old 04-06-2009, 11:47 AM
Pocket's Avatar
C100 E5 Oil pressure gauge
C100 G8 Alt gauge signal
Old 07-07-2017, 03:12 PM
LS2Swapped92's Avatar
G8 is not for the ALT gauge (voltmeter)
The volt gauge on the 3rd gens is supplied power through the gauges fuse in the IP fuse panel.
G8 looks to be a switch to turn the alt on/off as shown here
Attached Thumbnails Oil gauge for 3rd gen F body/ LS1 swap-screenshot-2017-07-07-15.07.36.png   Oil gauge for 3rd gen F body/ LS1 swap-screenshot-2017-07-07-14.22.08.png
Old 07-07-2017, 09:00 PM
Pocket's Avatar
You are correct
FWIW, for 90-92 LS swaps, G8 is only used for 12V IGN on the fan relays. The alt function is not used
Quick Reply: Oil gauge for 3rd gen F body/ LS1 swap
