94 z28 with ls1--ur the man if u got the answers
I currently have a 99' Z28 that was wrecked by my wife(yes, I still love her). LS1 engine/trans are in perfect condition. My dad has a completely restored 94' Z28 with a blown LT1(cracked head). I have heard the horror "cost" stories of doing a LT1 to LS1 conversion, but my question is if I have all the needed conversion parts on my 99, would the cost still be extreme to convert them over to the 94? I'm talking full convert--wiring, gas tank, electronics, exhaust, cradle....etc.
You don't have to mess with the Fuel System..that is a big mis-conception. You already having the Car will help make it easy.
Read this.. it will give you an idea..
https://ls1tech.com/forums/conversio...to-95-z28.html
I noticed you had to use the LS1 steering components. Would I have to do that or just use the LT's steering? You were installing a 6.0L while I'm dropping in that LS1
Not any difference between the 6.0l and the LS1 when it comes to the Wiring and how to hook it up.
You will have to use the LS1 Steering.
Basically the easiest way for you would be to un-bolt the K-member as-is from the LS1 Car with the Engine on it and stick it up right under the LT1 Car. I believe the Brake Lines will even bolt right up to the LT1 ABS Module.
im doing a swap like this right now, putting a ls1 in my 97 z28....if you need help let me kno i figured out pretty much every problem , im waiting on my trans from the shop thats building it and ill be done so shoot me a pm if u get stuck...
i blew up my lt1 too haha right after i conveted it to a lt4 heads and cam well not right after but like 6 months after..... the 93-97 z28 look bettter a lot of ppl agree and ls1 is just in my opinion the best new motor and going to be one of the best motors built..
and steering wise, yes u have to use ls1 steering i tried to cheap out and plus i couldnt find a k member at first. i tried conversion motor mounts which will work and fit the problem is, the rack and pinion , they do bolt in the same location and are interchangible but the difference is the angle of the actual pump where the steering colubm and lines go in to its back on more of an angle torwards the firewall this is because the motor is shaped more "square" than the lt1 and if you try to use the lt1 rack and steering it will hit the headers and you will be dealing with clearance problems, just go for a k member....and rack and pinion , you will also need the steering link that connects the columb and the rack......the rest of the suspension will fit from your lt1 car the lower control arms struts all that on to the ls1 k member.... i swap the brake lines from my lt1 k member... they are the same deisgn the only difference is the angle and hole to mount the motor mounts... the lt1 brake lines fit exactly on the ls1 k member, and also the ls1 brake line fit in to the ls1 car...any other questions just ask
also its not to bad, im at goin to be about 6000$ by the time im done, but i spared no expense i got a head and cam built motor, low miles from a vette, having 2000+ into my trans being bullet proof with custom converter...and tons more i proby could have easly cut it in half id say if you got a complete car to swap from, around 3000 or so for the car and just nikel dime stuff
Hey i am doing this swap also but with a 2000 LS1 and 95 z28 camaro. Also had heating problems and head gaskets were blown.
My question is could you keep the Kmember from the LS1, still connected to the suspension and control arms and brakes, and just bolt that onto the 95? Because on the 95 camaro the suspension is kinda shot and the LS1 suspension is still good so does it fit nice?
I put a LY6 (iron block 6.0 with L92 heads) into my 1994 Firebird Formula. I've got about $6-7k in the whole thing including the purchase price of the vehicle. It's really just bolt-ons with VVT with weight reduction mods. I've got a UMI road race K-member, Harwood Formula hood (which is like... half the weight of the stock metal hood), and a number of other things.
The point is, most of the cost/headache comes in with wiring... just go ahead, do yourself a favor, and pay for a professionally-made wiring harness. I was just fortunate to have a wiring professional in my family
I just ground out the mount hole on the crossmember. Check out my post https://ls1tech.com/forums/conversio...-2000-ls1.html
